Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Cracked keyboard I've had my MacBook for about 10 months, and a week or two ago, I noticed a small sliver of flappy plastic coming off of the edge of the keyboard. I'm right-handed, and it's at exactly the spot where my right wrist hits the edge of the frame. Has anyone had (or heard of) this problem? It seems like a weird design flaw. Computer's working fine, but I'm afraid it's falling apart.
  • commatose Sep 02, 2008
    it's definitely a macbook. nothing's squeezing out; it's kinda splintering. here's a pic, although the flappy thing just fell off.
OK, that is the "Top Case". I hope your machine is still under APPLECARE. If not I would call Apple and have it on record. The issue is a defective, splintered top case that Apple has acknowledged. For more info into Macbook defects try :
 MacBook - Appledefects
The computer is less than a year old which means You APPLECARE is still active. I would def contact APPLE and go on record as once 1 year from the retail date has passed, you will be responsible for and costs for parts, labor and possibly shipping.
Posted on Sep 02, 2008
    Novelist:
    Champion:
  • 382 Answers
Are you sure it's a macbook and not an ibook? The macbook has an embedded kebboard. It's ribbon cable and connectors are inside of the laptop as opposed to the ibook, which is installed on the top case. The Ibook did have issues with the clear or green ribbon cable squeezing up from under the right side.
Posted on Sep 01, 2008
Hi i'm trying to take apart a toshiba satellite l655-s5096 and as far as I can tell I've got all the screws but it won't release. I've ben looking for a manual but I've had no luck. If...
take all the screws off the bottom (including the screws hidden by the optical drive), turn the laptop over, open it. there is a small strip of plastic right above the keyboard, pry it loose and remove the 4 screws from underneath to release the keyboard. disconnect all the exposed ribbon cables and any other cable connector that you can see. once you've done this pick a spot on one of the edges to start prying it apart. Use a small screw driver or plastic pry tool if you need it. (on this model I started with the top right hand corner.)
Jul 02, 2011 | Computers & Internet
My Dell Insprion got wet and now the keyboard doesn't work
let it dry out for a couple of days and try it. blow it out with a hair dryer. buy a replacement keyboard on ebay or use a usb keyboard
Oct 26, 2009 | Dell Inspiron 1501 Notebook
Top Case cracked
Mine has the same problem and I work for a company that uses mac's that also have had the same problem. It is a design fault. Take it to your nearest apple store and state this and they should change it.
Jun 25, 2009 | Apple MacBook Housing, Top Case with...
BMW 525i 2002 check engine oil level notice every 4 weeks
You must use 5w\40 or 10w\40 remember BMW recommends castrol for engine oil
Jul 30, 2017 | 2003 BMW 325
Change of CMOS battery in IBM Thinkpad 1400 2621
This battery is hidden under the keyboard slightly up and to the right of center of the keyboard. To get it out is a pain.
Start with the computer sitting flat, lid closed, lid latchs facing you.. just like you were getting ready to open and use it.
Spin it around, rear ports facing you. Right above the external video port, on the right hand side, there are two screws, at a diagonal UP from the port itself, very close to the bottom edge of the LCD. Remove them. There is a small notch between the screws, using a small flat-blade screwdriver, pry up in the notch and pop the platic backing free from the rear of the laptop. DO NOT open it more than a small crack, you are just popping loose a small plastic tab. Open it too wide and you will lock it closed again or break the plastics when you open the LCD lid.
Spin the machine around again, and open the LCD carefully as far back as it will go normally. Find the Power Button. The Power button is to the far right of a plastic 'strip, with 4 other buttons on the far left. There is a small clear plastic strip overlying this button 'tray'. Find the small notch in the bottom edge of the clear plastic strip, use the flat-bladed screwdriver, and gently pry up, popping the plastic strip out of the tab holes in the tray. Under this plastic strip is a black adhesive 'strip' that has a house, magnifying glass, etc. markings on it, and 'i Series' or somesuch printed on it.
Using a razor blade, peel up the black adhesive strip on the left and right ends of the button 'tray'. You will find two small silver screws. Remove these. Then using your screwdriver, or as I did, a dental pick, *gently* pry up the entire tray from the BACK edge of the tray, and by lifting up the left side of the plastic tray. You will have to work it out from under the edge of the LCD bottom on the left side. DON'T yank on it, there is a small cable attached to the bottom of it. You will be able to rotate it toward you and roll it over, exposing the small latch holding the cable in place. Its a small, press-fit latch like what holds a keyboard cable in place. You'll need to work it open by lifting the left and right edges till the latch becomes loose. Pull the cable straight out of the slot, remove the entire plastic 'tray', and set it aside.
On the far upper right of the keyboard there is a small metal tab holding the right upper edge of the keyboard. Reach around to the back of the computer, right-hand side rear, find the little square thumb-notch, and pull it out. The latch on the upper right edge of the keyboard should retract. Now, while lightly pressing down on the keyboard, push the keyboard away from you. It should slide backwards and the front tabs on the front keyboard edge will pop out of the slots. Lift up the touchpad area, popping up the bottom edge of the keyboard, clear of the plastics, then pull the keyboard slightly toward you. It should pop loose all the way around. DO NOT yank on it, there are 3 small cables attached underneath. You wil need to lift the keyboard up enough to reach the cables and pop the lockdown tabs loose, then pull the cables straight out of the slots they are in. The cable slots are attached to the motherboard, the cables are attached to the keyboard.
Removing the keyboard will expose a flat silver panel underneath. There are 5 screws holding down the panel, 4 in a 'box' configuration on the left, and a single one on the right, and several slide-tabs around the edges. Remove all 5 screws, then slide the whole tray to the right, while lifting up. The entire tray will pop up, with the video card heatsink attached on the left-underside of the tray. Set this aside. Directly in the middle of the big hole you now have is the battery. Its smaller than a standard desktop motherboard battery, looks like a small silver button. Gently pry up on the bottom-left edge of the battery, very carefully or you will break the plastic clips holding it in place, and pop it out.
All done. Reverese order to put it all back together.
Feb 21, 2009 | IBM Thinkpad I1400 2621 Planar TV...
GE Refrigerator slow to make cubes
I had the same problem with mine a month ago. The plastic feed tube to the water solenoid valve was cracked and letting a large portion of the water go under the fridge on the floor. I just cut the cracked tubing off at the valve/fitting area and inserted good tubing into the fitting and tightened it up, it has been perfect since!
Dec 05, 2008 | Refrigerators
Bluish hazy texture on my screen
It sound like the light engine is going out or already out. I would take it to a certified Hitachi dealer have them check it out then I would call Hitachi to have them fix it for free.
Nov 14, 2008 | Hitachi 50VS69 50" Projection HDTV
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
119 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
