Question about Pentax Optio S Digital Camera
Optio s - flash problem in low light
I have had this camera for a month now and had no problem on in door and out door pictures. But yesterday when I took it to my daughter's dance performance, I had a lot of problem with the flash. I took some picture of her about 3 to 5 feet away. I can see the flash was on since it is very dark in side. But about half of the picture came out as if the flash is not on. The other half looks like the flash is on. That's when the flash setting is on 'auto' mode. Change it to 'flash on' mode does not make any difference. It look like to me that the flash is on too early or too late about 50% of the time. Is there anyone else has this problem? Is there settings I should try?
    Master:
  • 542 Answers
Read the photo data (EXIF) and confirm what setting the flash was in. It may have been set to off by mistake. For close indoor shots I usually don't depend on the Auto setting, just manually force the flash on to get proper lighting. If you use the Auto setting take into consideration the white balance and the type of indoor lighting you are using.
Posted on Sep 08, 2005
SOURCE:
D80 won't take pictures sometimes unless I turn it off and on
It may be that you are shooting in a light level that is too low (indicator light) try upping the ISO and are you using the built-in flash or a separate flash?
Nov 25, 2008 | Nikon D80 Digital Camera with 18-135mm...
Won't turn on, only flashes a light
use rechargable minnimum 2500mah batteries -----solved
Nov 05, 2008 | Pentax Optio E60 Digital Camera
Flashing red light
Make sure all your settings in the menus are as you want them.
Also: You can try to reset all the settings from the menu setting.
Jul 06, 2008 | Pentax Optio M20 Digital Camera
My Pentax Optio E40 Camera
The built-in memory only has about 8 pictures or so. You have to buy a memory card to insert in the same section where the batteries are inserted.
Apr 03, 2008 | Pentax Optio E40 Digital Camera
Optio S - low light autofocus problem
Using "spot" focusing area insted of "multiple" works best in low light (and I guess it gives you the best results in any situation).
Sep 08, 2005 | Pentax Optio S Digital Camera
Pentax S4 no flash problem
Well this camera has no manual controls so it's merely compensating for the lack of available light by lowering the shutter speed. I don't think there's very much you can do about it -- maybe you can try to lower the EV -/+ setting (I forget what it's called, it makes your image darker or brighter). If the camera didn't lower the shutter speed you would simply get dark pictures where you can't see anything
Sep 08, 2005 | Pentax Optio S4 Digital Camera
AWB problem on 555
I noted that situation, but was my fault because i've been using Bulb or tungsten in outdoor pictures...!!! AWB works fine most of the cases except in some indoors where i have to use manual WB. Please be aware that if you have enough indoor light could be a good idea to disable the flash, try and error......
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Major blurring/sharpness problem with Pentax Optio 50; help!
Thanks for posting the photos.....they tell a lot. You need to return that camera and get a refund. The camera is defective. The first two photos were taken under good lighting conditions and you should have gotten good shots. The last two were taken at low light and the camera was using 1/30th of a second shutter speeds which could account for some blurring due to camera movement. The last one appeared to be a flash shot and it selected 1/30th second. Not a good thing for the camera to do. But all photos have the appearance that you are shooting through a fog. And all photos were shot with an ISO setting of 200. There is something wrong with this camera for that to happen on the first two shots. I checked the EXIF data that is embedded in the photos. That gives you the shutter speed, aperture setting and focal length, ISO settings, and other information. I have not seen a review of the Pentax Optio 50. But the older S50 did not get good reviews. If I were you, I would look for a different brand of camera. For a few dollars more you can get a Nikon 5600.
Aug 30, 2005 | Pentax Optio 50 Digital Camera
Pentax Optio S Digital Camera Logo
74 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
