Question about Pentax Optio 550 Digital Camera
550 Problem: Dust collecting inside Viewfinder
Yesterday I noticed a white fleck on the Viewfinder of my 550 which I could not wipe off. Upon examination with a loupe I discovered that there are all kinds of particles (perhaps 25 of them) have collected on the inside of the viewfinder's glass, and a few specks could also be seen when looking through it from the front end as well. They cannot as yet be seen when looking through the viewfinder as they are basically invisible to the naked eye. I wonder if others can check their 550 camera viewfinder under a loupe or magnifying glass to see if they have this problem as well. If so, there is a serious dust-sealing problem with this camera - at least within the viewfinder itself. Unfortunately, I believe this could potentially extend to other areas inside of the camera, posibly including the inside of the lens, as I do not expect that the Viewfinder chamber is a module totally sealed off from the rest of the camera's innards. I am quite worried about this and intend to contact Pentax Canada on Monday to see what they will do about it. It does not as yet interfere with camera operation - at least at this point, as it is still only several weeks old, but it could potentially get serious enough where it could interfere in it's use. As it is, the lens cover is so fragile that it does not provide a perfectly tight seal, and I have often found specks of dust on the front lens element as well.
    Master:
  • 542 Answers
I had hoped that a few people would check their cameras and posted replies before I contacted Pentax about my dust problem, but nobody has so far. But it's interesting that someone else posted a message this morning that he has some dust inside the lens of his 550. Anyway, this morning Pentax Canada told me that there should definitely be NO dust inside the viewfinder or the rest of the camera for that matter. Although the Viewfinder is "almost sealed" from the rest of the camera, it is not a total seal - which means to me that if dust can get into the viewfinder, it can get into the rest of the camera's interior - including the lens and imaging chip. They have asked me to bring my camera in so they can remove any dust particles that are inside. Basically, they told me that the only place I should see any dust is inside the lens cover, which is meant only as a protective covering rather than a seal from dust. Even then, they claim that any dust on the outer lens would only enter while the camera is being used. That one I don't buy, as the lens cover is very flimsy and can easily be accidentally spread open while the camera is turned off.
Posted on Sep 08, 2005
SOURCE:
White stains boxster interior
the wrong cleaner was used at some point and bleached out the color. take to body or interior shop and they can redye the problem spots.
Aug 19, 2012 | 1999 Porsche Boxster
Small flecks of dirt on clothes
If its noisy too then sounds like drum bearings gone / leaking oil/grease...
Apr 12, 2010 | Washing Machines
Blury view finder
On the left of your viewfinder you will find a small knurled wheel. By turning this wheel you adjust the diopter settings of the viewfinder. You probably accidentally moved it and didn't know it.
Aug 11, 2009 | Olympus SP-550 UZ Digital Camera
Cleaned inside of viewfinder, now AF focus lights gone
Then you learn, when everything works fine, dont mess with it! Have a look at the gold pins that rely the body to the lens. Also check that your lens manual switch focus is engaged... Try a friend lens to see if its your cam or the lens...
Jul 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
When I turn on my hitachi CP-X205 projector, there is a very noticeable "fan" sound. Yesterday while using the projector it made a sound and then turned it self off. After unplugging it, I plugged it back...
Hi!
You need to clean the projector. Take of the filter and clean it, open the topschell of your projector and clean it.
In time a projector collects a lot of dust inside, if you dosenrt regulary clean the filter the dust pass it and stucks inside the projecotor. Use compressed air for the job but be verry verry carefull so you dont damage anything vital. If you arent sure how to to it i sugest you take it to a electronic repairshop, its cheap and they will clean it properly.
Good luck to you
Nic
Feb 27, 2009 | Hitachi Office Equipment & Supplies
YELLOW SPOT ON SCREEN
There may be a dust fleck on one of the LCD screens inside your projector. I had a similar problem and managed to clean it. But it requires you to dissassemble the entire projector !!!. If you are not technical, don't do this yourself. !!!
Feb 16, 2008 | Sony VPL CS5 Multimedia Projector
LCD screen stopped working
sounds like the LCD screen viewfinder may have been twisted or accidentally catched or got hooked or snagged on on something at one stage and pulled something, if the screen went yellow it means the three wires going to it are possibly broken or the small white clip was slowly coming undone inside the Viewfinder for the red and green to no longer work to complete the image also indicates why the buttons on the viewfinder are not responding, try twisting the viewfinder very lightly whilst on, but most likely the small white clip holding the wires has come off at the elbow inside the camera
Apr 22, 2017 | Sony Handycam DCR-HC21 Mini DV Digital...
A faint spot in all of my photos!!!
For me the issue was flecks of dust on the CCD. Complete fix for d40x effected as follows:
(You will need a 'rocketblower' or similar air cleaning device)
Take the lens off. Set camera to Manual setting and spin around to 'bulb' setting, press the button to shoot but hold it down. You will see the CCD exposed inside the hole where the lens usually attaches. Then taking care not to touch the CCD with the rocket blower give it a few blasts of air onto the ccd. (Possibly before you do this hold the camera at an angle to the light and you might see the dust flecks I had on the CCD.) Then replace let the button go and replace the lens. Voila.
Sep 09, 2007 | Nikon D40x Digital Camera
Help! My air ilter quit!
I bought one a year ago and never thought it work well in cleaning the air. I get more dust on my counters than collects in the pure-ion. I recently got a letter from an attorney saying they are settling a class action suit on these purifiers because the are not effective. I called brookstone and they said they will refund my money because of the law suit. Good luck.
May 10, 2007 | Brookstone Pure-Ion UV Air Purifier
Pentax Optio 550 Digital Camera Logo
120 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
