Question about Asko 24 in. D3350 Dishwasher
Help for my asko diswasher
Hi
I have a asko d1986 diswasher. we have just had a power blackout and now my dishwasher won't start. lights on, not flashing and I can't change from normal wash to any other type of wash. any ideas? F7 keeps flashing. need to re-boot this dishwasher. is there a product manual online??
  • Marther Jan 30, 2013
    Hi there, I'm looking at buying one of these second hand. Would you know its years of manufacture, the original price, or the energy and water efficiencies? Thans very very much.
  • Asko Master
  • 19,396 Answers
Unplug the washer for ten minutes, see if this clears the problem.
Posted on Aug 28, 2008
  • Ginko
    Ginko Aug 28, 2008
    If it does not clear the error.
    F7 Door lock release fault.
    1. Bent pull-rod for door latch.
    2. Bad door latch solenoid.
    Check the door latch, if you cannot fix it by replacing the door latch the main control board may be faulty and in need of replacement.
    You can buy parts and service repair manual here
    Or here
Asko D5424 water not going in to diswasher
sounds like the water inlet valve is not working. it is not real hard to replace.
Jun 01, 2014 | Asko 24 in. D3120 Dishwasher
Dishwasher stops mid cycle
Do the foll. things:
1)Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so. 2)if ur dishwasher doesn't starts then: First, check the usual suspects: Make sure the circuit breaker isn’t tripped and that the wires at dishwasher’s power junction box aren’t burnt. If all that checks out, then go right to the control panel area.
Asko dishwashers have had problems with the wiring in the control panel area burning or melting– very messy. While your problem may not be as dramatic as that, the problem may still be visible. You may find burnt or discolored wire terminals or the spades on the start button switch may be burnt– anything burnt or discolored has to be replaced. You can buy any replacement parts you need right here.
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Asko 24 in. D3120 Dishwasher
Diswasher does not turn on
remove the back panel and check if you have power there, if not you have a faulty wire or fuse
Mar 09, 2013 | Asko D1996HNDL Built-in Dishwasher
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
ASKO Dishwasher F2 light flashing
Hold the Rinse button for 5 seconds to reset.
Jan 19, 2009 | Asko D1776 Built-in Dishwasher
ASKO D1986: Water pump running constantly
Solved by draining water from bottom pan.
Jan 18, 2009 | Asko 24 in. D3350 Dishwasher
Asko diswasher 1485 - no lites, still has power -will not turn on... is there a reset???
no reset but at the circuit breaker... there are two fuses in the back where the power cord goes into the machine... there is also a thremo fuse that in the the back it is black rubber in the center...let me know if it helps
Aug 30, 2008 | Asko Dishwashers
try holding in the start button for 10 sec to see if it resets,or the board could be faulty part no 8801201
Apr 02, 2008 | Dishwashers
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Asko diswasher
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Nov 23, 2007 | Asko D1776 Stainless Steel Built-in...
Asko 24 in. D3350 Dishwasher Logo
455 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
