Question about Haier HRF10 Top Freezer Refrigerator
Freezer cold, but Fridge only a little cool
The Top freezer stays cold (frozen), but the bottom section (fridge part) only gets cool. (its not the door seals, and the cooler knob is set to coldest) I have three of these models, a couple months ago (still under warranty) this happened on one of them and I called the repair service and they fixed it in about 5 mins (said a screw had come lose), now this has happened on the other two...right after warranty expired. Any suggestions before I call the service again ?
Thanks.
  • 770 Answers
Sounds like you have a defrost problem either the Timer /Heater or Bi-metal stat is bad. you can unthaw and the unit will work fine for about a week until it frosts up again Where was this screw they said was loose?? have them check the defrost system.
Posted on Aug 28, 2008
Top section of my side by side kitchen aid frodge stop cooling bottom is still cooling and freezer still working
send the model number?if the freezer is cold but in fridge the top is warm and the bottom is cold it sounds like you have a bad evaporator fan motor,all it does is cold starts in the freezer at the evaporator coil,and the evap fan blows the cold air into the fridge section,warm air rises so if the fan isn't working the cold air will stay down low and the warm air will stay up on top,open the freezer door,if you don't hear the fan blowing in the freezer i would have to say the evap fan motor is bad,if the fan is working one of the doors could have been left open and the air ducts froze up or you could have a damper in your model,it's just a door that opens and closes to let the air blow in but send the model number so whoever helps you can look up your fridge,usually the model number for a sxs is in the fridge section open the fridge door look up on the right hand wall up near the ceiling or in the middle of ceiling and there should be a tag with model and serial numbers just send the model number,
Jan 07, 2018 | Refrigerators
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
FREEZER GETS COLD BUT BOTTOM DOES NOT
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 23, 2011 | GE GTS22KBP Top Freezer Refrigerator
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
Sep 26, 2007 | Maytag MFD2560HES Bottom Freezer French...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Haier HRF10 Top Freezer Refrigerator Logo
280 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
