Question about Zanussi FJS1225W Front Load Washer
Zanussi IZ 12 Washing Machine Front Load
My machine is around 8 years old & I've had no problems with it until now. I put a load on synthetic programme/ quick wash cycle as normal - when I came back to it about an hour later, only the power light & door lock light were on - the display panel was, & still is, blank. I drained a small (approx 3/4 washing up bowl) of water through the drain plug & managed to opened the door to get the washing out after switching the power off, so presumably it had got most of the way through its cycle maybe apart from the final spin? The drain filter was clear when I checked it, although I do clean this regularly. All I can get now is the power light - no other display lights or beeps. Has something happened to a circuit board?
  • shauna m Sep 23, 2013
    The main board (brain)of the computer is gone. its only gauranteed up to 5yrs.
    sorry the main brain of the washing machine is gone if the lcd display is not workin or if the lights are not on the cycle selections
  • 734 Answers
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Posted on Dec 03, 2008
Door remains locked and machine doesn't start running
Did you check and see if the child lock is active?
Mar 25, 2017 | Zanussi FJ1254W Front Load Washer
My Zanussi nexus fl881 wont spin. Can you tell me how old this washing machine is and how to fix/whether to get new one?
6/8 years old.....Souynds like new motor brush kit needed. price of parts about £30. plus labour possible 30 mins work to fit..Hope this helps
Apr 01, 2011 | Zanussi F1045W Front Load Washer
Zanussi washer iz 12 error e10
Switch off.
Press and hold the two buttons again and switch on.
The appliance will beep or flash, let go of the buttons, the leds will scroll.
Press and release the temperature button until the bottom led of the 2nd column is lit.
Let me have the error code.
Switch off, on and off again
Nov 28, 2010 | Zanussi IZ12 Front Load Washer
Zanussi washing machine, conditioner doesn't empty
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi IZ 12 pump access
You should not need to remove anything to check and clean pump filter.
Open the filter door at the bottom right front of washer, there you will see the pump filter cover, unscrew the filter anti-clockwise, and remove the filter, and clean same.
With the filter out, you will see the filter housing, which is fastened directly on to the pump, have a good look inside the housing, and see if anything is stuck in there.
Refit filter, and test.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Zanussi IZ12 Front Load Washer
Iz 161 w jet system washing machine
I have had a similar problem before, check that the hose outlet is not blocked, or that the drainage pipes are not blocked.
Jul 07, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi zwf 1231 w front load washing machine
all connections to the zanussi modules are plug and socket and are keyed so you can't put them in the wrong place
Jul 05, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi iz 161
Hi there!
Congrats on the twins! Getting any sleep yet?
I think the problem is to do with the water pressure sensor, or hoses inside the machine.
This sensor determines when there is enough water in the machine, and turns the valve off.
If you are competent to have a look, then continue -
Isolate supply and turn off water connections -
Remove the lid by removing screws at the rear, and slide back.
Check the air hoses that are near the drawer area. It is not uncommon for one to just come loose, or rip.
Reassemble and turn on to check opperation.
If this assists you, please spare a moment to rate as Fixya! as I would apreciate it. Thank you.
If not, contact me again for further items to check.
Jun 18, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi iz 161s
e10 indicates a problem with water supply
Oct 12, 2007 | Zanussi IZ161S Front Load Washer
Fitting a new door seal
unplug machine. Pull off retainer clip from the front , with both hands inside push up the seal untill its free. Then with the new seal apply washing up liquid to the gap on the seal. And fit this is fiddly. Then pull the spring you removed to loosen abit and with a screw driver to keep it in place throught the door lock thats why youve unpluged it. strech the spring around. the ease on the front part of the seal and replace the clip. put on a wool wash to check for leaks. appliance doctor
Feb 05, 2007 | Zanussi IZ161S Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
302 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
