Question about Pentax Optio S Digital Camera
Optio S Powerup Problem
I just realized that when I take the battery out of the camera briefly and put it back in (for example, when I put the battery back in after a recharge), the camera does't powerup properly. It shows the green light and it doesn't go off and the camera hangs and nothing is functional. Has anybody else experienced this problem?
    Master:
  • 542 Answers
Perhaps this is related to the focus problem you posted? Battery drain because the lens system hangs up on power-up? If this new lens system fail to open properly you can have battery and focus problems?
Posted on Sep 08, 2005
Hi , I have a Pentax optio S10 the auto focus has stopped working , sometimes I have a yellow triangle with " ! " and a hand signalling stop , any ideas please ? thanks
remove the batteries first'
pull the memory stick put it back in
put good (proper milliAmpere hours) new batteries in the camera
If that does not work \turn off the camera
remove the memory stick
Repeat power up
Aug 19, 2010 | Pentax Optio S10 Digital Camera
Got my Pentax Optio A10 soaked in the rain today. TOTALLY!
soak and, I mean soak your camera inside and, out in 90% isoprophyl (rubbing) alcohol remove the battery first then after 24 hours dry the camera out using a hair dryer on the warm setting.
Jul 15, 2010 | Pentax Optio A10 Digital Camera
My pentax optio 50 lens got stuck half-way and now the camera turns on briefly and then goes off automatically. I've replaced batteries and pushed the lens in manually, but it's still not working. Mary
This is tricky .. if you have no warranty, and have already managed to push the lens in.. I suggest pulling the lens outwards gently AS you simulataneously turn the camera on. You may be able to use a small suction-cup affixed to the lens to do this :)
you could hold the lens-cover open with tape so the cover is less likely to be damaged.. good luck, this problem is common, annoying, and usually not worth repairing (*although with some cameras it can be done again and again!)
Aug 30, 2009 | Pentax Optio 50 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
Pentex optio camera
Hi, Same problem. Somebody had suggested gentle tapping. With nothing to loose if it doesnt work my wife banged it more than gently onto a desk and it started working. Hurrah! Dont blame us if it breaks.
Raghu and Faye
Aug 27, 2008 | Pentax Optio S7 Digital Camera
Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
Feb 25, 2008 | Pentax Optio M30 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Pentax Optio S Digital Camera Logo
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
