Question about HP iPAQ RZ1715 Pocket PC
IPAQ 1715 not recognized
I recently had a hard drive crash. I've been trying to get my iPAQ set up again on my new hard drive. I can no longerlocate my installation CD for my iPAQ, but I was able to download Active Sync 3.8. The problem is that my computer isn't recognizing the iPAQ - it says there are no drivers installed for it. I've gone to the "download drivers & software" section on the HP website, but nothing there has been helpful. Since I can't locate my installation CD, am I just stuck with an iPAQ that won't sync, or is there something else I can do?
    Master:
  • 450 Answers
All you should need is Activesync. Try the following... From your PC .......... with IPAQ cradled click on Start, Control Panel Double-click on System Click on Hardware, then Device Manager Click on '+' to left of Universal Serial Bus Controllers Click on '+' to left of Windows CE USB Devices Right Click on HP USB Sync Select 'Uninstall' Uncradle IPAQ Reboot PC
Posted on Sep 08, 2005
Hard drive crashed. New hard drive does not recognize Diskgo Edge, Suso I can restore
Hello Sharleen,
Your question is not understandable, If your hard disk has crashed, only professional data recovery services may help you out.
Make sure you go to DiskGO and get the new update for your drive, I some cases your hard drive needs updates to be recognized by your system
Sep 29, 2015 | Hard Computers & Internet
Blue screen error plus blank start up screens but the start up sound can be heard.
Have you changed any BIOS settings? I would open your BIOS menu and make sure it is set to "AHCI"
Aug 21, 2012 | Lenovo IdeaPad U550 Notebook
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
I have the toshiba external hard drive 500gb with NIT back up. I've recently backed up both my personal files and the programs. I need to wipe my computer due to some imbedded problem in...
im not familiar with this NIT back up
have you tried running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
http://www.nit-solutions.net/index.php?option=com_frontpage&Itemid=1
hope this will help you
Aug 10, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
I have a compaq s5100nx desktop with a crashed 80 g ide hard drive.i am trying to replace it with a 500 g drive but the drive is not recognized by the bios i have tried 2 different drives already. However...
did you configured the Hard drive jumpers correctly?
Was the original HD set to master or Cable select?
if so please set your new hard drive to the same jumper settings as the old one.
Mar 19, 2011 | HP Compaq Presario S5100NX (DM172A#ABA) PC...
No Hard Disc found after crash
Compaq uses F10 at boot to initiate the recovery program resident on the hard drive partition normally called "Recovery". If you cannot initiate the hard drive at boot then press F1 to get to setup and see if the hard drive is recognized there. If it is not then you will have to troubleshoot the hard drive.
If you have another laptop to try the hard drive out or a laptop to IDE hard drive adapter  (cheap) to connect to a desktop computer as a slave drive you will either verify that the hard drive is bad or it is good and a boot sector problem is at hand. Also if you can get the drive recognized as a slave drive you can either rescue data or format the drive.
These are preliminary steps so post again when you have more information. Steve Medley
Jan 26, 2009 | HP Compaq nx6310 Notebook
Cannot find hard drive error after repair
Couldn't find the hard drive or the DVD drive? If it's the hard drive then the crash was due to a hard drive failure and the hard drive will have to be replaced. If it's the DVD drive, you will need to get a floppy for it and flash the bios in order for the machine to recognize the DVD drive again.
Jul 22, 2008 | IBM ThinkPad T30 2366 Notebook
When I connect my iPAQ to my PC, it will not recognize the device
It shouldn?t take more than 10 to 15 seconds for Active Sync to detect the iPAQ once it is inserted in the cradle and it turns on. First off you need to update to the latest version of Active Sync which is 4.5. Lots of synchronization issues have been fixed since 3.7 so here is the link to the download: http://www.microsoft.com/downloads/details.aspx?FamilyID=9e641c34-6f7f-404d-a04b-dc09f8141141&DisplayLang=en A couple of times over the past few years I?ve gotten a non recognition error as well. Each time I?ve been able to get away with removing and installing the latest version and my problem has been solved.
Jul 20, 2007 | HP iPAQ H5555 Pocket PC
HP iPAQ RZ1715 Pocket PC Logo
149 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
