Question about Dynasty DGRSC 36-6 Gas Kitchen Range
Where to buy....
I need both light bulbs replace.  Also, I need to replace one electrical connector to the light socket.  This is a special part, because it needs to be rated for high temperatures
  • 639 Answers
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
How do I replace a burned out backup light on a 1998 cheverolet silverado c-1500 pickup truck?
Removal & Installation Cab/Chassis gm-06-00-1071.gif
To Remove:
  1. Disconnect lamp assembly electrical connector.
  2. Remove nuts and lamp assembly from bracket.
  3. Remove lens screws.
  4. Remove lens, gasket and bulb.
To Install:
  1. Install lamp assembly and nuts to bracket.
  2. Connect electrical connector.
  3. Install bulb, gasket and lens.
  4. Install lens screws.
Except Cab/Chassis gm-06-00-1075.gif
To Remove:
  1. Lower endgate.
  2. Remove 2 tail/turn signal lamp assembly retaining screws.
  3. Rotate tail/turn signal lamp assembly and remove from vehicle.
  4. Disconnect lamp assembly electrical connector.
  5. Remove bulbs by pulling straight out of bases.
To Install:
  1. Install bulbs by pushing straight into bases.
  3. Install tail/turn signal lamp assembly to vehicle and secure with 2 screws.
Jul 17, 2010 | 1998 Chevrolet C1500
How do you replace the passenger side low beam on a Pontiac Grand Prix '07? I can't get to it from the back, so I'm wondering if there is a special tool to take off the front lens.
raise the hood. lift upward on the headlamp retainer(its a off white color tab right behind the lamp asm.in about the middle of lamp)pull the headlamp asm. outwardenough to release the headlamp asm from the upper fascia support.position the headlamp asm. away from the vehicle body to access the electrical connector. disconnect the electrical connector from headlamp asm.remove headlam asm. from vehicle. remove headlamp bulb /socket from the headlamp ,by turning counter clockwise. remove headlamp bulb/socket from the headlamp asm. install new bulb in socket and reverse procidure .
Feb 22, 2010 | 2007 Pontiac Grand Prix GXP Sedan
How to change lowbeam headlight bulb on 02 chev trailblazer
  1. Open and support the hood.
  2. Remove the grille.
  3. Pull up on the retaining tabs in order to remove the headlamp assembly from the headlamp panel.
  4. Disconnect the headlamp leveling electrical connector from the motor/actuator if equipped.
  5. Disconnect the headlamp electrical connector from the headlamp assembly.
  6. Remove the side marker socket from the headlamp assembly.
  7. Remove the park/turn socket from the headlamp assembly.
  8. Remove the headlamp assembly from the headlamp panel.
  9. Remove the access cover from the rear of the headlamp.
  10. Disconnect the electrical connector from the socket.
  11. Rotate the bulb and socket counter clockwise in order to remove the bulb and socket from the housing.
  12. Disconnect the electrical connector from the socket.
  13. Remove the bulb and socket from the headlamp.
Replace the low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
Oct 17, 2009 | Chevrolet TrailBlazer Cars & Trucks
How to change front headlamp bulb? Low beam
  1. Open the hood.
  2. Remove Grille.
  3. Remove the 2 retainers on back of headlamp assembly and remove the headlamp from the sheet metal panel.
  4. Remove the access cover from the rear of the headlamp.
  5. Disconnect the electrical connector from the socket.
  6. Rotate the bulb and socket counter clockwise in order to remove the bulb and socket from the housing.
  7. Disconnect the electrical connector from the socket.
  8. Remove the bulb and socket from the headlamp.
Installation Procedure Important: • Replace a high beam bulb with another high beam bulb. The high beam bulb has a black socket. • Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
Oct 14, 2009 | 2002 Chevrolet TrailBlazer
How do you replace the fog light bulbs on a 2004 buick regal?
Notes FOG LAMP BULB REPLACEMENT - FRONT
REMOVAL PROCEDURE
  1. Remove the front bumper fascia deflector.
  2. Disconnect the electrical connector from the front fog lamp bulb/socket. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Rotate the front fog lamp bulb/socket counterclockwise to release.
  2. Remove the fog lamp bulb/socket from the front fog lamp assembly.
  1. Install the fog lamp bulb/socket to the fog lamp rotating clockwise until fully seated. CAUTION: Refer to Halogen Bulb Caution in Service Precautions.
  1. Connect the electrical connector to the front fog lamp bulb/socket.
  2. Install the front bumper fascia deflector.
Jun 16, 2009 | Buick Regal Cars & Trucks
NEED TO REPLACE A TAIL LIGHT BULB IN A 2005 CHEVROLET IMPALA
and Repair Notes TAIL LAMP REPLACEMENT REMOVAL PROCEDURE Open the rear compartment. Remove wingnut and pull back the rear compartment trim panel from the tail lamp. Remove the wingnuts from the tail lamp. Remove the tail lamp from the rear body panel. Disconnect the electrical connector from the tail lamp. Remove the tail lamp socket, turning counterclockwise. Remove the bulb from the tail lamp socket. Remove the sidemarker lamp socket, turning counterclockwise. Remove the bulb from the sidemarker lamp socket. INSTALLATION PROCEDURE Install the bulb to the tail lamp socket. Install the bulb to the sidemarker lamp socket. Install the sidemarker lamp socket, turning clockwise. Install the tail lamp socket, turning clockwise. Connect the electrical connector to the tail lamp. Install the tail lamp to the rear body panel. Install the wingnuts to the tail lamp. Pull back the rear compartment trim panel to the tail lamp and install the wingnut. Close the rear compartment.
Jun 08, 2009 | 2005 Chevrolet Impala
Need to replace the bulb on 2000 grand am gt
Hi, this guide will help you replace the bulb on this vehicle.
1.
Step 1
Remove the keys from your Grand Am's ignition and engage the parking brake. Turn the headlight switch to "OFF."
2.
Step 2
Loosen the hood with the release latch beneath the instrument panel. Then, step out of the car and pull up on the auxiliary release latch beneath the center of the hood.
3.
Step 3
Lift the splash guard out of the engine compartment and pull up the two retaining clips holding the headlamp assembly in place. Once they're loose, pull the assembly away from the car.
4.
Step 4
Turn the headlight bulb socket counterclockwise to remove it from the assembly, and then detach the electrical wiring connector from the back of the socket.
5.
Step 5
Pull the old bulb straight out of the socket and replace it with the new bulb.
6.
Step 6
Reattach the electrical connector and screw the bulb socket back into the assembly.
7.
Step 7
Reposition the assembly and test the new headlight to make sure it works before replacing the splash guard and closing the hood.
Please rate and god bless:)
May 07, 2009 | 2000 Pontiac Grand Am GT
How do I replace a taillight lens on a 1991 Geo Storm?
Rear Turn Signal, Brake and Parking Lights
STORM COUPE
  1. Disconnect the negative battery cable.
  2. Lift the luggage compartment floor carpet toward the front of the vehicle and remove the spare tire cover panel.
  3. Remove the ten plastic retaining clips from the rear end trim panel.
  4. Disconnect the luggage compartment lamp electrical connector.
  5. Remove the luggage compartment trim panel and the rear end trim panel.
  6. Disconnect the rear combination lamp assembly electrical connector. Fig. 1: Rear Turn Signal, Brake and Parking Lights — Storm
  1. Remove the seven nuts and the rear combination lamp assembly from the vehicle.
  2. Disconnect the rear combination lamp electrical connector.
  3. Remove the four bulb sockets from the rear combination lamp assembly and remove the four bulbs from the sockets. To install:
  4. Install the four bulbs to the sockets and install the four bulb sockets to the rear combination lamp assembly.
  5. Connect the rear combination lamp electrical connector.
  6. Install the rear combination lamp assembly to the vehicle and the seven nuts.
  7. Connect the rear combination lamp assembly electrical connector.
  8. Install the rear end trim panel and the luggage compartment trim panel.
  9. Connect the luggage compartment lamp electrical connector.
  10. Install the ten plastic retaining clips to the rear end trim panel.
  11. Install the spare tire cover panel and the luggage compartment floor carpet.
  12. Connect the negative battery cable.
Mar 21, 2009 | 1991 Geo Storm
Brake lights quit working
Tail lights acting insane?
We had the same issue with our 2000 Pontiac Montana. Brake lights, turn signal lights, running lights, back-up lights and emergency flasher didn’t work at all or operated at random. The cause: poorly designed aluminum contacts on the tail light circuit board and wiring harness connector arced over and disintegrated with normal use.
Pull the tail lamp assembly, remove the electrical connector and look for burned contacts on the connector plug and the connector socket (they call this long plastic piece with the socket the circuit board: it includes the four bulb sockets. Replace the circuit board and the wiring connector.
You can DIY this job with basic auto mechanical/electrical skills and tools. The two circuit boards and the two connectors set me back $230 (2009 cost) for new parts. The electrical contacts on the factory replacement parts are improved.
I needed a T-30 torx driver to remove the tail light assembly (you need this to change out bulbs, too), wire cutters, wire strippers, electrical tape and an electrical lug crimper to do the job.
Aug 02, 2008 | 2003 Pontiac Montana
Dynasty DGRSC 36-6 Gas Kitchen Range Logo
138 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
