I have changed my routers IP address but now i cant access its configeration interface
  • seige381 Aug 29, 2008
    um yeah i fixed it by hard reseting the router to the defualt settings and i can now access the interface.... but i cant seem to be able to get the router working behind my modem... we just replaced the modem as the other was dead as telstra put it so i bought a netgear modem so i could continue to use the current router that i had but they dont seem to want to work as one and if they do its for a very short peroid of time then it stop working again... and i now i cant even run my xbox straight off the modem
    Master:
  • 397 Answers
Make sure your computers IP address is in the same range as whatever you changed the router to.
Posted on Aug 28, 2008
Need to allow a telnet session thru a speedstream 5660 modem/router having a public ip and allow it to connect to a private ip on the internal LAN. how do i accomplish this?
According to the user manual:
Page 16:
HTTP Web-browser Access
Most HTML browsers can be used, though Internet Explorer 4.0 or Netscape 4.0 are recommended. IE 2.0 and Netscape 2.0 and their predecessors are not supported. The HTML interface can be used to access the LAN (or WAN) IP address or it can be used with FTP to upload and download files to and from the router.
To log on to the modem via HTML:
1 Bring up your favorite web browser.
2 Enter the Ethernet IP address of the router (10.0.0.1 or Speedstream) in the "Location" or "Address" area where you enter web page addresses.
3 Refer to "HTML Web Interface" on page 20.
Page 20:
HTML Web Interface
The HTML interface for the router first displays a page showing the current configuration of the router. The first page also provides links to the following functions:
Advanced Setup
Leads to a more detailed interface with several links that allow more in-depth configuration of functions available on the router. This interface provides the following links:
Configuration Procedures
Status and Statistics
Command List
This is where the user manual ends. I would suggest clicking "Configuration Procedures" and find the section for configuring Network Address Translation (NAT).
In that section (if it exists), you'll want to provide the private IP address of the computer running the Telnet server and forward port 23 to this IP address.
If NAT capabilities do not exist, I would consider changing the router to Gateway mode (described in the user manual) and buying your own router to handle the NAT firewall.
Dec 29, 2010 | Efficient Networks SpeedStream 5660 Router
Whats the security code to acsess internet
WEP: wired equivalent privacy
WPA: Wifi Protected Access
These are the 2 kinds of security enabled for wireless routers.
These keys will be stored in the router interface.
If you open the router interface, you can find the key.
For opening the router interface u need to type the ip address of your router in the address bar of your web browser.(mozilla firefox preferred)
It will open the interface of your router.
You will need to login to the router before you can make any changes.(certain routers comes with the login password that is provided in the user manual of router)
Dlink router default ip address is 192.168.0.1
Dec 27, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do I get my WEP or WPA key?
Nov 29, 2010 | D-Link DI 514 Wireless Router (DI-514)
Changed the IP address on Zhone 6218-I2, can't access browser UI.
Go to start -> run -> cmd.
When the window comes up, type: "ipconfig". The address that says "Gateway" should be the address of the router.
If that is too confusing, try the following combinations:
192.168.0,1,
192.168.0.254,
192.168.1.254
192.168.2.1
192.168.2.254
May 23, 2010 | Zhone (6218-I2-200) Router
I want to change the default SSID name
log on the router using the default gateway IP address and change it. if you need more details post router model/make and we'll assist
Feb 02, 2010 | Computers & Internet
What is the routers address for configeration
192.168.254.254 is the default IP address of Efficient Networks Speedstream 2623 router.
Default password to login is 'admin'.
Oct 12, 2009 | Siemens Efficient Networks SpeedStream...
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
How do i access the configeration set up of my router. It is a thomson speedtouch. Have got to it before but can not for the life of me remember how. cheers in advance steve
Try this
Proceed as follows:
1 Open a Web browser.
2 In the address bar, type your SpeedTouch™’s IP address or DNS host name
(http://speedtouch.lan or 192.168.1.254 by default)
The SpeedTouch™ Home page appears, from where you can navigate to all
the configurable aspects of the SpeedTouch™.
For more information on the Web pages, see “4 SpeedTouch™ Web Interface” on
page 21
Mar 25, 2008 | Computers & Internet
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
David Payne
David Payne
