Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
LiftMaster Garage Door Opener
The right bottom roller pin keeps pulling out of the bracket that holds it making the opener not open or close.  Shouldn't there be an endcap on the roller pin to keep it from pulling through the bracket?  Please identify the needed part.
Many thanks.
Lisa
  • Brett Stave
    Brett Stave Jul 07, 2015
    Our garage door repair technicians provide fast & friendly professional services across Oklahoma City including maintenance, installation, garage door opener repair and troubleshooting. Call now (844) 334-6701.
  • 504 Answers
IF YOU ARE TALKING ABOUT THE ROLLER ON THE DOOR - THE TRACK IS TOO WIDE ALLOWING THE ROLLER TO COME OUT. USE THE CLAW END OF A HAMMER TAP THE TRACK MOUNTING BRACKET AT THE WALL TO MOVE THE TRACK IN CLOSER TO THE EDGE OF THE DOOR
Posted on May 30, 2010
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a LiftMaster garage door opener. It has started to act up a bit, and I can't seem to locate the problem. It opens just fine, but when we try to close it, with either the remote or the wall control,...
If the opener feels any resistance it will act like this.Make sure that the rollers on the door to frame are oiled well and turn easily, move in and out easily as well, you can also turn the screw to increase the resistance stop pressure.Oil the rollers well
Jan 22, 2011 | liftmaster Chamberlain Garage Door Opener...
I have liftmaster garage door opener P/N 41A-5483-4. It worked normally. but all of sudden, when door closing, it reverses automatically at half way down, and garage door light bulb starts blicking 6...
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4. After checking those things, there is a "up force" and "down force" adjustment on the opener, try increasing the "up force" by turning the adjustment in the direction of MORE force.
LiftMaster Garage Door Opener Frequently Asked Questions
Jan 02, 2011 | liftmaster Chamberlain Garage Door Opener...
My garage door won't close ... starts to close but at different points it stops and opens again
Dec 31, 2010 | liftmaster Chamberlain Garage Door Opener...
GARAGE DOOR WANT CLOSE, USING CLOSER WILL MOVE A LITTLE BUT LIGHT FLASHES, SENSORS SEEM TO BE WORKING
I recommend this to everyone with garage door opener problems:
If not, lubricate the hubs of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well.
Dec 07, 2010 | liftmaster Chamberlain Garage Door Opener...
Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Oct 07, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberplain Garage Door Opener
The screws that attach to the garage door from the arm pulled out of the garage door and left holes in the panel. I tried to anchor the screws but they keep pulling ou..what do I have to do to secure the screws in?
Jan 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
May 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
331 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
