Zanussi aquacycle 1000 (fla 1002 w)is emptying,not washing or spinning,it done 2 loads then stopped.
  • 185 Answers
SOURCE: My Zanussi Aquacycle 1000 will
check the lid switch
Posted on Mar 28, 2008
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
beltronic205
  • 1474 Answers
SOURCE: Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Posted on Oct 06, 2009
barkencoa
  • 3463 Answers
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Posted on Dec 31, 2009
barkencoa
  • 3463 Answers
SOURCE: My zanussi aquacycle 1200 is not spinning all the
Check the filter is not blocked.
This is located at the bottom front right of washer behind a drop down flap or cover.
Unscrew anti-clockwise to remove and clean.
Please rate my solution.
Thankyou.
Posted on Jan 17, 2010
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
Access motor belt zanussi aquacycle 1000
There is usually a hatch at the back of the washing machine.
Mar 17, 2014 | Washing Machines
Zanussi aquacycle 1000 wont wash or spin properlyZ
take it to the proffesional mechinac for repair.. if its guaranttee is not due go back to the store and change it....
Sep 19, 2013 | Zanussi FJS1225W Front Load Washer
Zanussi FLA 1001W does NOT spin
You need to check the brushes in the motor first, replace if less than 3 or 4mm long.
If brushes o/k, then could be a module or motor problem, apart from the belt being broken or worn of course.
Hope this helps.
Jan 23, 2010 | Zanussi FLA1001W Front Load Washer
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Aug 11, 2009 | Zanussi Washing Machines
Will spin on empty, but not with load in.
  • this is like this we have to get a sattilite worker to put it under it to solve it
Feb 16, 2009 | Zanussi FJD1666W Front Load Washer
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
May 29, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
