Question about Toshiba e800 Pocket PC
Problems with e800bt
After about a month since i received the pda i had problems with it. It had randomized hard reset even with full charged battery, i think cause of a false contact. i sent it, by italian support centre, to repair at the teleplan centre. it returned to me, and after 2-3 months i had again the same problem. i sent it again in repair to the teleplan center but after 2 months i got again the same problems.
    Master:
  • 903 Answers
I don't know much about italian warranty conditions bt in Germay you can ask to change the PDA after it is repaired three times without success! I think it is the best to contact Toshiba Italy directly and tell them your story and ask what to do! TOSHIBA EUROPE GMBH - Sede Secondaria in Italia CENTRO DIREZIONALE COLLEONI Palazzo Perseo - Via Paracelso, 10 20041 AGRATE BRIANZA (MI) Tel. 00 +39 (0)39 68730.1 Tel. 00 +39 (0)39 68730373 Telefax 00 +39 (0)39 68730369
Posted on Sep 08, 2005
TOSHIBA PORTEGE G910 POWER MANAGEMENT problems
try xdadevelopers for this solution,best site for xda pda problems
Mar 23, 2010 | Computers & Internet
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
Acer N30 PDA charging problem
My PDA n30 is not a year old yet - when I put it to sync and charge everything looks fine but when I unplug it does not stay charged - it blacks out straightaway.
Please help
Jun 09, 2009 | Acer n30 Pocket PC
No power When I press power button.- Battery is full
Try changing ur battery if it doesnt help then do this
try pressing the reset button near the charging port on the pda if it doesnt work try to hard reset it as follows
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update
other wise check xda forums for software dead HTC http://forum.xda-developers.com/
pls do rate me if i fixed ur problem
Feb 24, 2009 | HTC Touch P3450 Smartphone
I was trying to move an address list from the computer to my hand held and suddenly it has Please Wait on the screen of the hand held and it will not turn off or do anything
try to hard reset
It is some time very important to Hard reset a PDA for example if you want your PDA to be factory default or or operating system corruption etc the following are the information, how to do a hard reset on every PDA as different PDA manufacturer have different methods.
To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-5 seconds. Release both buttons and you will see a confirmation screen asking you if you would like
Dec 31, 2008 | Computers & Internet
Palm Tungsten E2 won't work after power cord is removed.
The traditional steps for resetting charging problems are:
1) press reset /while/ the power cord is plugged in
2) unplugging the battery for about 30 seconds, then plugging it back in
You have done #2, but I do not know if you have done #1. Try it, then try to recharge again. If that fails then you probably need a new battery. I have found them on eBay before.
Feb 22, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Acer n30 will not turn on
Trya hard reset, mine was off for 6+ months and wouldnt charge. After a couple of hard resets - bingo, fully charged battery.
Oct 31, 2007 | Acer n30 Pocket PC
The Screen is back and it won't charge
Hello, it isn't that simple as a broken charger. Try the following thing. Connect battery to the PDA, check that the battery LID is connected FIRMLY to the body (there is a contact there that woun't allow the PDA to start if the lid isn't connected properly, you may want to check it too, look carefully for a small black thing and check that it can be pressed). Then connect the pda for half hour to the charger, even if no light or amber led is flashing. Then make a master reset as showed here and connect the PDA to a usb sync cable with your computer. Press simultaneous the soft reset and the power button, then press only the soft reset button. The PDA should start. If not, there is a problem with a DC converter component on the mainboard or the connector I was talking about before. Even if the charger is broken, your PDA should power on from USB cable. Good luck, feel free to ask further questions and always remember to rate replies received from this site :)
Feb 27, 2007 | HP iPAQ H2210 Pocket PC
Sync Doubling Calendar & Contacts in Outlook 2002
your t5 is UNSTABLE possibly due syncing to an old username from an old PDA. To correct this: -delete manually the doubles (PDS has a tool but none for outlook) -perform hard reset on your t5 -hotsync - creating a new user name (do not use the old one) -you will be asked to use the same profile name for the outlook Then you should be good to go.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Ipaq RZ 1710 won't switch on
If you've backed up your PDA, I'd strongly suggest trying a hard reset. This has happened before to one of my RZ1710 pda's. The only solution was to hard reset it. This can be done by pressing the two extreme left and right buttons (The Calander, and Home button) and the reset button on the bottom of your iPaq with the stylus.
Sep 11, 2005 | HP iPAQ RZ1710 Pocket PC
Toshiba e800 Pocket PC Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
