Question about Epson C64 InkJet Printer
Epson C64 Photo printing
Even when using genuine Epson cartridges my photographs are too dark - increasing the brightness only partialy solves the problem and is very 'hitty missy' .
Downloaded pics. print fine.
Thank you in anticipation of an easy solution
DougC
  • 353 Answers
It's a long time now without any help forthcoming on this problem. If you still have it, can you post a new comment and I will try and help you fix it. Otherwise let's call it solved!
Posted on Feb 14, 2009
All colours except the black appear to be printing on my Epson C64 InkJet printer. What could be the problem?
On this printer, the black colour is a separate cartridge.
It is possible that is has run out of ink or maybe is blocked in some way.
Try removing the black cartridge and hold it up to a bright light to check the ink level.
Make sure the contacts where the ink flows out are clean and not blocked with dirt.
If there is plenty of ink but it still won't print then try a new black cartridge.
Please rate my answer if you find this helpful.
Many thanks,
Chris
Mar 05, 2011 | Epson C64 InkJet Printer
Epson Stylus Photo 1400 Prints Dark Shadows Red!
Did you use Epson Genuine Cartridges? ????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 15, 2010 | Epson Stylus Photo 1400 Printer
Wont print black or yellow ink
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
Dec 16, 2009 | Epson Stylus C64 InkJet Printer
Extreme color lines in all printing: text and images. the printer has never been great at printing images but has now started to print with bright color lines through any print job.
Have you been using Epson Genuine Cartridges?
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
This is the only advice I can give you. If you find this helpful, pls rate me.
Sep 29, 2009 | Epson Stylus CX5000 InkJet Photo Printer
My epson c64 only print blank pages, everything else is normal
how dry it is
cartriges do dry out
even new ones
wash the botom and make sure they bleed
failing that the carige might be bent
Sep 16, 2009 | Epson C64 InkJet Printer
Epson stylus c64. Replaced low ink printer
1) Unplug the power cord, wait 30 seconds, then plug back in.
2)Did you follow the directions exactly when replacing the cartridge? Did you peel off the protective film?
Jul 03, 2009 | Epson Stylus Photo R300 InkJet Printer
How to increase brightness of the photograph ?
Use a free image editing software like Picasa from Google. http://picasa.google.com/ . You can perform basic photo editing tasks easily using this including brightness, colour, crop, resize, redeye etc. For Professional editing you will definately need Adobe Photoshop.
Mar 02, 2009 | Adobe Computers & Internet
Printing too dark
Check the properties of the printer in Windows, make sure it's not using any odd color profiles. My Epson uses E411__1 as it's color profile. There might also be brightness and contrast sliders in the printing preferences that you can adjust or return to default.
Aug 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson C64 will not print
well it is the chipset on the compatible cartridge. it is not good.
try another one ..
Jan 11, 2008 | Epson C64 InkJet Printer
Printer will not print
More info needed here. Are any lights on or flashing? Have you tried going through the cartidge instsallation process again (but just taking out and putting back the same cartridges when told to put in new ones)? Are the unrecognised cartridges genuine Epson or compatibles? Have you tried putting genuine Epson cartridges in (even empty ones will do) to see if they are recognised? A response to these question will permit me to give you much more specific help.
Nov 26, 2007 | Epson C64 InkJet Printer
Epson C64 InkJet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
