Question about HP iPAQ RX3715 Pocket PC
File Storing? Is it possible to reduce the size of Ipaq file store on my HP Rx 3715 an add the free space to the memmory?
    Master:
  • 450 Answers
No, it's not.
Posted on Sep 08, 2005
How do you reset it to factory settings
To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 30, 2009 | HP iPAQ RX3715 Pocket PC
Download driver for hp ipaq rx 3715
Hi!
You can download the drivers for your hp ipaq by clicking on this link.
Under the window it will open the extreme bottom there is a download link.
Thanks
Rylee
Jan 29, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Helo i have a problem
The dreaded "allign screen problem" strikes again. This is a known bug of these rx ipaqs. You should simply try to see if the ipaq passes this stage if you try to allign the screen a few times. If not, try a firmware update/rom update (from the hp site) If this woun't work then the problem is located on the motherboard,where a small chip called the touchscreen I/O controller has failed. This isn't fixable by replacing the screen, only the whole motherboard. Unfortunately most of the first generation rx 3715 units (first revisions) carried this problem just waiting to happen.
Please ask more details if you need to better understand any of these methods above.
Jul 11, 2008 | HP iPAQ RX3715 Pocket PC
HP iPaq 3715
is this windows compliant and if it is in the control panel check to make sure that your sound that you use is default set some times this can lead to a no sound usuage
May 28, 2008 | HP iPAQ RX3715 Pocket PC
Ipaq totally dead after leaving it in my car for two weeks, temperature down to -6C
Its possible (but not likely) that when you took it into a warm room condensation built up inside it. Try removing the battery, memory cards and letting it sit in a warm, dry environment for a few days and try again. If nothing changes I suspect that a component has failed, but -6F is still within the operational range of commercial electronics. If your device is still in warranty then I would call HP up and ask for a warranty replacement. Let us know if you have any other questions and please don't forget to rate this posting.
Feb 12, 2007 | HP iPAQ RX3715 Pocket PC
Data access problem with SD card for rx 3715
SD cards can be tricky. One good program that I like is pocket mechanic..... http://www.pocketgear.com/software_detail.asp?id=12178&associateid=373.
Sep 14, 2005 | HP iPAQ RX3715 Pocket PC
Can I backup to iPAQ File Store?
Yes. Storing the backup image file to iPAQ File Store or to a storage card is an easy method to recover when having to hard reset the unit.
Sep 12, 2005 | Compaq iPAQ BlackBerry H1100
Rx3715 - Help needed!
For data files, you navigate to them with File Explorer, tap and hold on their names, a pop up appears. Choose Move to, and then you'll be asked for a location. But data files probably should be moved to a storage card, rather than the File Store. As for programs, it's risky just to move them from one location to another. The safer course is to Remove them (Settings -- System -- Remove Programs) and re-install them to the new location. When installing via ActiveSync, when the installer asks: "Install to default location," answer No, and you'll get a menu asking where. Choose File Store from the drop down. Good luck.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
Hebrew Support for IPAQ 3715
Try Laridian.com They specialize in Bible and some language software for PDA's. Good Luck.
HP iPAQ RX3715 Pocket PC Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
