What's a Tape Monitor Switch on the Harman Kardon AVR20 II?
How do I determine if this switch is set or not? I have never used it. Does not mean it might not be set accidentally.
  • tcwarlin Aug 28, 2008
    You are the man Dan! Thank you, thank you, thank you. That worked absolutely fantastic. I am thrilled.
    You are a genius. I owe you BIG TIME.
  • 4,234 Answers
There should be a way for you to hear either the source when you are recording or the result off of the tape. There is usually a switch for this called the tape monitor. This allows you to "monitor" either the source or tape. In tape mode, without a tape actually being used, you will still get a little sound from what is called cross-talk inside the unit. The sound will be very weak as you described. Look at teh front panel and make sure that the TAPE 2/Monitor is off. It is the third from the left of the rectangular switches.
Dan
Posted on Aug 28, 2008
HK AVR 247 no power up
Could be an open internal fuse or power supply failure.
Sep 19, 2016 | Harmon Kardon Harman Kardon H/k Avr20 Mkii...
How do I fix my audio/video receiver that has no sound coming out of it?
If your unit has a speaker protection mode (5-8 second delay when 1st turned on) defective speakers and/or speaker wiring may be causing the protection circuit to do its job...protect the speakers. Disconnect all speakers and test HK in all modes (tuner, CD, DVD, etc.) using headphones. If you still cannot hear audio then it's time for a shop repair. Although I recommend factory authorized service whenever possible, a "local" shop that is certified by other well-known brands may be an option. If Yamaha, Onkyo or Luxman certified your local repair shop then it's a sure bet that they can properly repair HK's no longer under warranty.
Mar 22, 2015 | Harman Kardon AVR 340 Receiver
Harman Kardon AVR210 - got power, lights, FM/AM stations, but no sound ?
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
May 04, 2011 | Harman Kardon AVR 210 Receiver
I have the Harman Kardon HK3370,I have no sound was working fine this morning before I left for My Job.after a 12 hour shift came home turn it on and have no sound check speakers and all are fine.
Make sure speaker switch is turned on, when it is the small box on the side of the display will illuminate. Make sure the tape monitor is off. Check that no one pulled out the pre-out to main-in bridges in the back.
Jun 16, 2009 | Harman Kardon HK 3370 Receiver
Harman Kardon AVR20 II Receiver Low Sound Level
This may sound silly, but please verify that the tape monitor switch in not engaged. The TST mode bypasses that section of the receiver. This is the most common cause. Since the TST signal is the correct volume, the output amp section is working correctly. One other possibility is the tone circuit having a problem, but lets verify the simple stuff first. I'll look up the tnoe circuit section in the meantime. Please update this when you can with your results.
Thanks,
Dan
Aug 28, 2008 | Audio Players & Recorders
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
AVR20 II
Yes, actually there is a capacitor which is dry and needs replacement. Is located on the front panel board
Nov 22, 2007 | Harman Kardon AVR 130 Receiver
Harman kardon soundsticks II
use a clear silicone based sealant (similar to the type used for caulking and in fish tanks) I'm guessing you used CA or superglue, and thats what melted your plastic, you're using too much also most likely.
Sep 11, 2007 | Harman Kardon SoundSticks II Computer...
343 people viewed this question
 Grubhead
Grubhead
