SOURCE: Amana APO95R Turning Off/Tank Light (!) On and Off
There are only two items that will shut it down after it is set to run. The bucket full which you took care of and low humidity in the area it is being operated in. Low humidity would not constitute a reason for returning it.
SOURCE: i have a amana pbh092b12mb
you didn't say what zone you're in but if you're north of southwest missouri you can forget about anything seeming warm below 30 degrees outside i tell all my customers to switch to emergency heat when temp's get below 25 for extended periods of time 2 days - weeks. either way you're at the mercy of the utility company on emergency heat you get hot heat and faster results heat pumps out of the box can only give you what they can generater from outside temperatures 35-55 they work great giving better than 3 to 1 but that falls off drastically when the temperature plunges
SOURCE: Amana AP125HD Portable Air Conditioner This
I dont have this one, but I searched for problems because I am thinking of buying one. Thanks for info above. This unit has a very high capacity, and a very high electrical load to match. Understandable that it needs full capacity 15 amp service.
