Question about LaCie Computers & Internet
My lacie Big disk 500GB drive will not mount even though it shows in Disk utility (unmounted) and in System profiler. When I run Verify Disk in Disk utility it says: ERROR: The underlying task reported failure on exit. Any suggestions? Cheers Charlie
  • charlie89 Aug 28, 2008
    Thank you, I think I will attempt to save the data somehow as cheaply as I can and then see if I can get it fixed.
    Cheers for all your help
    Charlie
    Guru:
  • 1,894 Answers
Try rebooting and hold down the option key, you should then be able to select the Mac partition.
Posted on Aug 28, 2008
  • 2 more comments
  • dewan nafees ahmed Aug 28, 2008
    If not, then put your Tiger DVD install disk in, and reboot holding
    down the c key, do not do the install ! but run Disk Utility from the
    Menu bar...run Disk Repair.
    If you try to repair a disk that cannot be unmounted, the repair will appear to start, but then stop as Disk Utility displays this message: "Repairing disk failed with error. Could not unmount disk."
    If you look in the Console (/Applications/Utilities/), you will see an entry like this:
    Verify and Repair disk “Storage”
    The disk “Storage” could not be unmounted
    Could not unmount disk for verification
    In some rare situations, your computer might not respond for several seconds.
    If you cannot determine which files are open on the disk that you
    want to verify or repair, restart your computer and then mount the disk
    again, or start up from your Mac OS X Install DVD or CD to repair.
  • LaCie Master
  • 19,396 Answers
Try first unplugging power, if it does not work try uninstalling and reinstalling disk utility
  • Ginko
    Ginko Aug 28, 2008
    Try first unplugging power from computer and Lacie disk for ten minutes, if the computer is a laptop or a Mac notebook, then also remove the battery at same times.
    If it does not work then try uninstalling and reinstalling disk utilit, Check if your lacie is displayed as external disk in your computer resources. If you are using Windows XP, for example, check if you have a new external disk in My Computer, in this case the problem is only with Lacie software, as the computer is seeing the disk.
    If the disk is accessed through a network also disable all firewall software to test the disk.
    If you have a different computer test also the Lacie on the other computer, to see if the external hard drive is faulty.
  • Ginko
    Ginko Aug 28, 2008
    Hi, when Lacie does a kind of tickling noise and it does not start, that means the disk is faulty. Testing it on a different computers also confirmed the diagnosys.
    When this happens you can fix it only by replacing the internal hard drive, all data inside are usually lost or recovered at an high price from specialised data recovery companies.
    The disk can be fixed for a not too high fee at any computer shop.
    If you just bought the disk take it back to seller.
    If disk is less then one year old contact Lacie to check if you can validate your guaranty, you find number on booklet that came with hard drive, or on Lacie website here.:
    LaCie - External Hard Drives
I bought today a lacie hard disk 500GB and instead of 500GB has only 9.99 MB space.What's the problem?
Sounds like your have a 9.99mb partition on your drive with the rest being free space.
If you are running windows goto the Computer Management program and check under storage> disk management to see if your 500gb drive is there. if it is delete the existing partitions and reformat the entire disk to NTFS
May 21, 2011 | LaCie Big Disk 500 GB Hard Drive
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Trouble seeing my lacie drive possible mounting issue
It sounds like the RAID controller in the LAcie drive may have failed. When this happens generally the data on the drive is left intact but you will require a new casing for the drives and the help of a data recovery pro to get the files off before you can re-initialize the set. Unfortunately all the good free/cheap utilities work only on single drives so you will need the help of a pro with high level software and additional equipment to retrieve the files.
If you are in North America I would recommend Armor-IT Data Recovery, they're listed in the FixYa service database for most US states. If you're outside North America, post your location and I will help you find an appropriate service.
Chris
May 28, 2009 | LaCie Big Disk Extreme with Triple...
Freezes up During Backups
I suggest an application called "Disk Warrior" it has always maintained high ratings among us Mac enthusiasts it has a hardware test function built into it and seems to be a little better at verify and repair functions than Disk Utilities which you can try also if you haven't yet. You may also consider trying a different firewire cable if you have one handy. Other than that a reformat should have put the disk back into an original state however the disk could have been damaged by not un-mounting it in rare mac cases. If you have the time you can also reformat the disk again although I would try the first two options first.
Apr 23, 2009 | Computers & Internet
Lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Feb 06, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
LaCie 500GB external will not show up on mac desktop. Blue light on, whirrs as if working but no icon on desktop (not mounted)
Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running Leopard, not positive if the same applies to Tiger. I hope this helps you
Dec 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
Help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Dec 25, 2006 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
133 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
