Posted on Jul 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer says error code oxc4eb841a - Office Equipment & Supplies
Anonymous
Level 2:
New Friend:
  • Expert 50 Answers
  • Posted on Jul 18, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
27056
Points
106
Need make and model of printer.
Epson wf 3640 error code 0xf3
Epson printers produced it simpler to print or scan the job. Epson has the correct item for you, whether you want it for your home or office. But. Error codes such as Epson Error Code 0xf3 happen primarily when any foreign object is stuck in the printer. You can go through the alternatives listed here in order to fix this. Or, at Printer Support, you can also have a word with our technicians.
Epson Printer Customer Care Number
The solutions listed above will surely be for you to resolve the Epson printer error code 0xf3. If you have any query regarding this error, you can always contact the professionals who can guide you better.
Kindly Visit our Website:-
https://www.printercustomerservice.co/blog/epson-printer-error-code-0xf3/
ERROR CODE: 0X9A
Gadgets, especially printers, bring efficiency to work helping us in accomplishing some tasks quickly. There are many manufacturers for printers, but Epson has proved to be one of the best in class. However, printers could be annoying when they produce errors or malfunctions. Epson Printer Error Code 0X9A is one such extremely common error that users seek information for.
Reasons for Epson printer error code 0x9a
There aren't a lot of complicated reasons for this error code; often printer errors are triggered by simple and petty causes. Epson printer error code 0x9a can occur because of
Solutions for Epson printer error code 0x9a
Now that you have a fair idea of what the problem is and the factors responsible, you can proceed with the solutions to fix the problem.
Clean the Printer
If there is debris or some obstruction in the printer, it can cause Epson printer error code 0x9a. Check and clean the printer. Open the top of your printer and look into it for dirt, or paper pins, scraps of paper, staple pins, etc.
Reset the Printer
Sometimes, resetting the printer is all you need to resolve the Epson Error Code 0x9a. For resetting the printer, turn off the power and unplug the power cable. Wait for 5 minutes then press the power and hold it down for a little more than a minute.
2answers
My printer ESP5210 is showing error codes 3501,3606,3507. What can i do to fix this
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
for more help visit https://cbrtechsolutions.net
Como resolver error oxc4eb841a en impresora HP deskjet 3050 serie J610
I have a problem, when I turn my Hp deskjet 3050 multifunction gives me an error code and not OXC4EB841A concerned
thanks
What is error code oxc4eb841a
Did you recently clear a print jam? Are all the little scraps cleaned out of the paper path and drive gears?
New printer - error when inserted cartridges: oxc4eb841a
Go to Ox.xxx.xxx HP Errors.
If you need more help post back!
Thumbs and testimonial are welcome!
I have a brand new HP Deskjet 3050. When first plugged in, it gives the error code OXC4EB841A (I can't tell if the first character is the letter O or the number zero). I can't install it or do anything...
The error is probably 0xC4EB841A. This is an internal failure of the printer. You can try to reset and power down the printer slightly differently then just pulling the power cord.
With the printer on, remove the USB cable, if in use, from the printer; I'll often remove this cable from the computer, as well. Open the front door of the printer and remove the ink cartridges. Remove the power cord from the back of the printer. Disconnect the other end of the power cord from the outlet. Wait at least 60 seconds. Plug the power cord into the wall outlet and then into the printer. Turn on the printer if it didn't come on. Wait until the printer warms up and then reinsert the ink cartridges. Make sure that the protective tape was removed from the cartridges. Close the access door and print a calibration page if you see a prompt for one. Scan this page.
Try to install the printer software and connect the USB cable to the computer and the printer when prompted to (if you are using the USB cable).
If the error returns, contact HP. A brand new printer will be covered by their warranty. (Depending on where/when you purchased the printer, you may be able to return it to the store for an exchange. This will depend on the vendor.)
I hope this helps.
2answers
Canon error code 6500
The PCI bus error is detected by the ASIC. - Logic board problem
k24674
ADMIN Andrew
ADMIN Andrew
