Question about Dell 942 All-In-One InkJet Printer
Printer is not working
The printer screen has a normal display and the computer keeps saying that the printer is busy and therefore will not print anything but it is not busy with any jobs. I have cancelled all prior jobs a number of times already and yet it still tells me that the printer is busy.
  • 62 Answers
The surest way to fix this problem is to disconnect the printer, remove the printer from the printers list in windows (assuming you're using windows and a USB connection) and unistall the printer driver. Reboot the PC. Re-install the printer driver and when during the install the driver installer asks for your printer to be present that's when you connect and turn ON the printer for the driver installation to complete. You may or may not have to reboot the PC again depends on the final prompts. Your printer should now work.
Posted on Aug 28, 2008
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
I keep getting error 50 or error 51 and the screen says unable to print. I have followed the instructions of customer service and cleaned the coding band and checked for paper specs to no avail. I...
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Sep 24, 2010 | Brother MFC 490cw Color Inkjet...
HP 6110 is printing different color than on the screen
computer monitors are capable of thousands if not millions of shades and hues of colors that even the most expensive professional grade printers simply can not print. greens in particular. if your creating something you know you'll want to print (say like a business card), you need to create it in "printable" colors. there are programs (like paintshop and photoshop) that can display on your monitor what will actually print. the results will shock you. all this post of course ASSUMES your printer is in proper working order, otherwise your problem will be magnified...
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
It says E in the small display screen it has and
Turn the printer off.
Disconnect the AC power.
Reconnect the AC power.
Turn the printer on.
Start the HP Support Tool software on your computer, and check the ink-levels on the printer -- no ink means no printing.
Do the lights blink in a specific, repeating, pattern?
Have you looked at and entered your model-number, and looked at the "common trouble-shooting" suggestions?
Apr 23, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Dell 2330dn - my printer won't print my work. It keep reading Parallel busy. What does this mean?
How is this printer connected to your computer? Is it connected by a parallel/centronics cable, or USB, or perhaps not connected physically at all, but via network (it's a network-capable printer)?
Also, you don't specify the operating system.
I would guess, that it was installed on the LPT (parallel) port, instead of a network port, and because in reality nothing is connected to the parallel port it is producing an error (explaining why it's called busy would be long and boring).
Anyway, please either check the setting of the port to which this printer is printing (find that in Printer Properties), or be more specific as to what your current situation is.
Dec 01, 2009 | Office Equipment & Supplies
Machine won't print
Scanner failure means that the scanner bulb is no longer working. There are a few things that can sometimes bring it back but it may be a permanent issue.
1) Make sure printer is directly into the wall and not a surge protector or power strip
2) Remove cartridges from printer
3) Unplug power from back of printer and wait 30 seconds
4) While printer is unplugged press the # and 6 keys and plug power cord in. Keep holding # and 6 until the printer has either powered off or it says semi-full reset
5) Go through initialization process - if it works great the issue with firmware is fixed. If not then the scanner bulb isn't functioning and you are looking at replacing the unit.
May 11, 2009 | HP OfficeJet 6110xi All-In-One Thermal...
Won't print says its busy
You need to clean NVRAM on Lexmark X7550 printer. Please follow the steps given below:
1. Power "Off" the All-In-One.
2. Press and hold the number button and turn the All-In-One back on. Press and hold the "Color Start" button and the "Check" button at the same time and turn the printer ON.
3. Release both the buttons once the printer is ON.
3. Press "Down" arrow button to go to the "Maintenance" menu entry. Press "Check" button.
4. Press "Down" arrow button until you reach "Manufacturers Test." Press "Check" button.
5. Press "Down" arrow button until you reach "Clear NVRAM." Press the "Check" button. The printer will restart by itself.
6. You will be prompted to go through setup again and to print an alignment page.
Next, try this printer self-test by following the steps given below:
1. Turn the printer ON.
2. Press the down arrow button till the screen displays “Maintenance.“
3. Press the "Check" button.
4. Press the "Down arrow" button till the screen displays “Print Test Page.”
5. Press the "Check" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 19, 2009 | Lexmark X7550 InkJet Printer
Printer busy message
See if this works:
Turn computer off
  1. Power off the printer.
  2. Close all printer covers and doors.
  3. Hold down the uparrow.jpg and downarrow.jpg (up arrow and down arrow) buttons on the printer and power the printer on.
  4. Release your fingers from the buttons when the message Diagnosing... appears.
  5. When Customer Mode and ESS Diag display, press the downarrow.jpg (down arrow) button until Test Print appears, and then press the select (center) button.
  6. Press the downarrow.jpg (down arrow) button until ContaminationChk appears, and then press the select (center) button twice.
  7. After the LCD displays Busy and the printer prints the ContaminationChk pages, power off the printer and power it back on.
Jan 20, 2008 | Dell 924 All-in-One InkJet Printer
Hp psc 2210 all-in-one printer is busy
I replaced the black ink cartridge and my printer keeps saying press enter to
align cartridges. I have done this a dozen times using up paper and ink and it
still says pres enter to align cartridges.
Jan 18, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
104 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
