Question about HP iPAQ HX2415 Pocket PC
SD memory cards and battery life
Is there a way to configure an hx 2415 to minimize battery drain? Can the card be turned on/off while installed?
    Master:
  • 450 Answers
Well, the standard tricks include: * always turn off WiFi and Bluetooth when not in use * turn down Backlight as much as you're comfortable with, and set it to turn off at a reasonable interval if nothing's happening * get a screen on/off toggle so you can turn the screen off if you''re listening to music. Actually, most of the audio software includes a screen toggle function; but you may want a general one in order to turn the screen off if you're recording, say. I'm sure other participants will chime in with more advice. If a card's in, it's on. I don't think it draws too much power.
Posted on Sep 08, 2005
I keep losing charge on my battery I have a sony xperia
  • Install "Repair Battery Life PRO" from Google Store, start the application, tap on Start, review the Health status of your battery.
  • If battery health status is "Good", there is a battery drain from an application behaving bad. Best method includes backup-ing your photos, contacts and other important things to your external memory SD-Card. You can use "Super Backup & Restore" from Google Store for that purpose. After backup, pullout your SD-Card and revert your phone to factory setting. After restart reinstall "Super Backup & Restore" and restore everything from it. After installing apps that you have been used, you will see the program that misbehaves.
  • If battery health status is not stated as "Good", replace battery with a new one
Nov 22, 2016 | Sony Cell Phones
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
How do u reset the lens error?
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 09, 2010 | Canon PowerShot A530 Digital Camera
When i turn the camera on it says lens error
Jun 07, 2010 | Nikon COOLPIX L18 Digital Camera
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
Lens error
May 31, 2010 | Nikon Coolpix S210 Digital Camera
Sd card cannot be read & internal memory of camera cannot be read
Which Kodak camera model?
It may not support a large SD (SDHC) memory card.
Remove the card and remove the batteries.
Turn ON the camera (I know, no batteries) for one minute.
Turn OFF camera and install batteries.
Do not insert the memory card.
Does the internal memory work?
If so, insert memory card.
If it's ok to format the card, do so.
If not, then use a USB adapter and copy the memory card to your [My Pictures] folder.
Format memory card.
Oct 01, 2009 | Kodak Cameras
I hav htc t-mobile wing i have inserted micro sd card in the sd card slot of it but in the storage card memory it says "total storage card memory : not installed" i have also tried other cards (witch...
Take out the SD card.Turn off the phone and take out the battery. Now insert the new SD card and then insert the battery. Turn it on and then new card should get detected.
Aug 08, 2009 | T-Mobile Wing™ Smartphone
My hp ipaq hx 2790 don't read the memory cards
Are the memory cards of similar size to what you have used before? Some large capacity ones cannot be used. Have you used a memory card before in this device so you know it was working?
Jan 08, 2009 | HP iPAQ HX2790 Pocket PC
Battery Life
Your SD memory expansion card may be damaged.
Try the same procedure without the expansion SD card.
Use the Casio QV-R40 10meg memory with same camera settings.
Dec 16, 2007 | Casio QV-R40 Digital Camera
HP iPAQ HX2415 Pocket PC Logo
42 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
