Question about Altec Lansing ADA 305 Computer Speakers
ADA885 Clicking My ADA885 speaker system I bought from DELL has a clicking sound when I turn on my system. This system has four speakers and a sub woofer. The volume display blinks too. What could be wrong? Thanks. Doug
  • aofdotcom Aug 31, 2008
    The FixYa person was very cooperative and helpful, but my system is a ADA885, which is old and not worth fixing. It functions fine when left on for long periods of time. But when I power it down with the computer is begins clicking and the display blinks. So, the session was helpful, but did not fix my problem. She suggested that I buy a new system and that's probably what I'll have to do. Thanks.
    Scholar:
  • 62 Answers
A few possibilities exist. I would first check all the connections, and wiggle all the connectors and plugs to see if any one of them is causing it including the power cable. Also try to play with the ON/OFF/Volume switch to see if that's intermittent. Second, for quick isolation of the problem I would connect them to another PC - did the clicking and flickering go away? If it did, then your PC's audio circuitry is causing it - possibilities: defective audio card, or Motherboard (MB) if it has integrated audio, bad connections on MB or audio card, if you're also using analog audio connections going from the back of your CD/DVD RW to the audio card/MB then remove those wires and see if that problem goes away - those wires are notorious for picking up all kinds of noise and feeding that noise to your audio controller. One other thing to try is to completely uninstall and reinstall the audio drivers or even try a different revision.
Posted on Aug 28, 2008
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
I would like to reinstall my speakers to my dell computer somehow they have been removed? Bar Code CN0D3431 48220 49T 06J3. I know longer can locate the installation disk?
There are a few simple things to check first:
Make sure your computer has a sound card.
You must be logged on as an administrator to perform these steps.
  1. Open Device Manager by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one. See Install or remove a sound card.
  3. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
  4. Click the General tab, and then look in the Device status box to identify problems with the sound card.
  • Make sure your speakers are plugged into a working power source and turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
  • Make sure that the speaker volume is not muted or turned down too low.
    1. Open Volume Control by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
    2. Under Main Volume, move the slider up or down to raise or lower the volume.
    gl_ico.png Note
    Some mobile PCs have an external volume control on the outside of the case. If you're using a mobile PC, check the external volume control.
  • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
Mar 14, 2011 | Dell A215 Computer Speakers
Clicking sound from Dell Speakers
How "often" does it click?
Internet Explorer does a "click" everytime you access a new web-page -- turn your speakers up/down to increase/decrease the sound.
Apr 25, 2010 | Dell 5650 Computer Speakers
Only the sub anbd one of the four tower speakers
The center one, right? You need to plug in all 3 plugs in the sound card, otherwise they won't work.
Feb 16, 2010 | Dell 5650 Computer Speakers
Trying to connect to TV but only center speaker works. System came with Dell Computer. Have 5 speakers and subwoofer????
Hi there bud ...Are you sure you using the RCA Cables , and not just the Cables that came with SPeakers?
Also make sure THat your T.V can handle 5.1 Channel Sound Speakers..
Hope you come right bud
Happy new year
Jan 07, 2010 | Altec Lansing ACS 45.1 Computer Speakers
I can't seem to find the drivers for my altec lansing ada885 speakers for my dell dimension 8100
i think you dont to find a driver for altec speakers, it sould be your sound card of your pc might need to have the drivers.
Nov 07, 2009 | Computers & Internet
Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Aug 19, 2009 | Dell 5650 Computer Speakers
I just bought the logitech LS21 speaker system for my dell and there is a subwoofer and then a left and right speaker to hook up. Where do i plug the subwoofer in at on the back of the compuer and where do...
The set up should be as this.cable plugs into headphone jack on your pc. that connectects to your powerd subwoofer it is power correct! then your small speakers connect to the sub box or thew should? look on the sub box usually front and on the bottom.if thee actual speaker connections then they will be on the rear.
Jun 11, 2009 | Dell Dimension 4700 PC Desktop
Logitech X-540 connecting to dell dimension 3000 ???
Your problem is you have a 3 channel sound card on your dell and you bought 5 channel speaker system. You can plug the green to green and get 2.1 sound but you will have to by a 5.1 pci sound like in the link below to get the full use of your 5.1 system.
http://www.mikescomputershop.com/asus-xonar-d2pm-sound-card-p-2357.html
Sep 08, 2008 | Logitech X-540 Computer Speakers
Altec Lansing ADA 305 Computer Speakers Logo
350 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
