Question about Koss KS3102 System
Koss ks3102 changed to pal and now i cant see ah thing so am basically screwed if u u can help me it'll be greatly appreciated. thanks in advance.
  • bukuru Sep 05, 2008
    i hit pal and key and now i can get the menu back
SOURCE: Koss KS3102 - Audio Problems
I think I have had the same problem. It seems like the system resets itself randomly. I think if you first turn it on in AV-1 or AV-2 mode, then hit the menu button on the remote, then scroll to ihe 'input'option, hit that then pick 'digital'. Do this for both AV-1&2. UI hope this fixes your problem!
Posted on Jan 28, 2007
SOURCE: Home theater system
optical or spidif rca - cable guy
Posted on Sep 01, 2007
  • 8 Answers
SOURCE: KS3102 Digital Optical Input Problem
What I did was turn on the system, don't put in any dvd in, or select an output 1 or 2. Press Menu on the remote, the display on the system display, not on tv should show Speaker, and other options. Select Input, select the one you want to use as the Optical Sound by press enter, then it will ask you on the system display input or optical sound input. Select optical input and press enter it will then say saved. You can then hit exit til goes back to where the display is back on main screen, or just wait til it exit by itself.
Posted on Jan 11, 2009
  • 79 Answers
SOURCE: home theater koss KS3102 need code to unlock it
heres your answer,,, follow this
I tried this, and it works prefect.
1) You do not need to have any disc in the player.
2) Press "menu" "1" "6" "7" "1" "9"
A special menu will appear with cursor pointing at region.
3) Press "OK", and the current region number is disappear.
4) Press "0", and your player now is region free.
Posted on Jan 22, 2009
SOURCE: Surround sound speakers won't work
I have the same problem. This works for some people, it didnt work for me. 1. Remove any discs 2. turn the unit off and unplug 3. wait about 20 secs and replug the power cord. 4. turn unit back on .Press dvd button on the remote to take unit to the dvd mode. 5.Using remote enter 76419. The display should say GOODBYE and go off. Press the power botton again to turn on and good luck
Posted on Jun 07, 2009
How do you reset pal/ntsc
pal/ntsc is a viedo format
Apr 23, 2011 | Koss KS3102 System
Sound no picture
Hi,i suggests there is a loose or broken connection on your video connections between the Koss KS3102 System dvd player and tv. Having sound suggests the optical pickup is fine. If you did not have sound then the Koss KS3102 System dvd player could have been broken. If checking the connections doesn't work, try a cleaning disk.
Take care.
Mar 25, 2011 | Koss KS3102 System
Does the ks3102 need a stand alone receiver to make surround sound?
Hi, It all depends on the system you are using. Most sound systems sub woofers comes with in built Amplifier, So if the system your using does not have amplifier to amplify and make the sound system sound better,That means, you will have to get a receiver for your system for great performance.
Hope that helps.
Thanks for using fixya....
Nov 27, 2010 | Koss KS3102 System
Cant get sound from tv on speakers.
lost remote and cant get sound from ks3102
Dec 16, 2009 | Koss KS3102 System
Change from PAL to NTSC
To begin, the first and second problems are completely unrelated.
If you bought a PAL TV and are playing an NTSC source, the result will be an invalid format. The two sources are not compatible. However, there are converters available, see: http://www.converters.tv/signals/ntsc_to_pal.html (just as an example).
To the second user. My first guess is that you need to select the proper input on your TV. Look for the "input" button on your TV remote and toggle through each input until you see a picture. The problem may be more complicated than that, but, to troubleshoot, I need to know: what TV you have, how many devices and what devices are hooked to the TV.
Mar 28, 2009 | Koss KS3102 System
Pal/ntsc
Those are the two common standards; PAL is used in Europe, NTSC in the US and they use different synchronization and resolutions which is causing your problem although it would seem that the menu should still appear since that is an internal function.
I suggest you email or call Koss for a suggestion; I don't believe you are the only one who has done this.
You might try pulling the plug overnight to see if the set will default to NTSC but as most sets today, it probably will remember the last settings and to access the area where this is stored is not a job for users.
A TV shop (if you can find one) will likely have a TV signal generator that can produce both standards and this will enable them to reset to NTSC.
Aug 03, 2008 | Koss KS3102 System
How to get colors on tv
sound but no picture
Dec 11, 2007 | Koss KS3102 System
Components value
This Component is red-red-black = 22ohms. Its of the same value as the R515A.
Jul 12, 2007 | Koss KS3102 System
Koss KS3102 System
I had a similar problem. Believe it or not, I randomly switched which ports the speaker wires used to connect to the receiver and kept playing with it with music going until all the speakers were making noise.
Jan 30, 2007 | Koss KS3102 System
Return to factory settings
set it by hitting general...(i know its hard to read) but hit preferances...than scroll back up to the top selection above pal...exit ...it will stop rolling and return to color
Dec 31, 2006 | Koss KS3102 System
Koss KS3102 System Logo
21 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
