Question about Neff Dishwashers
Hi I have a neff s5459x1/21 dishwasher that will not drain. I had a tech out today that charged us $143 and could not diagnose the fault he said it was either a board or a pump. Wash cycles work fine only will not drain i'm thinking pump any help please
  • 639 Answers
Dear friend,
ngfam at you service!
Why did you pay him more than a $75 service call if he can't and didn't fix anything!!!
Tell him to fix it and credit the 148 towards the job!!!!
WOWWWWWWWWWWWWWW
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Neff s5555xogb/70
Hi Jez, it sounds as if the heating element is faulty, im not really au fait with domestic dishwashers as i work on commercial equipment , i would say tho the fault you expressed is probably going to be the element
Dec 05, 2012 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff dishwasher error code e25
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Oct 13, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Neff dishwasher pump continues to run after cycle finished
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. Also after the program is completing to the final stage the drain vavle/pump must work and cut off If this does not happen then the voltage at the inlet valve/drain pump must be checked or the fault relates to the controller. This means the controller is a suspect.
Jul 26, 2011 | Neff Dishwashers
Neff s4459n2 dishwasher not draining the water
It is so common that the drain does not work in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has not drained then the drain hose pump/valve and fittings which are located on the underside of the machine must be checked. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve,, check the voltage on the drain pump during the cycle . If no voltage is present the program controller can be faulty.
Apr 19, 2011 | Neff 24 in. S5456 Built-in Dishwasher
My dishwasher wont drain
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 08, 2010 | Neff 24 in. S5457X0GB Built-in Dishwasher
Dishwaser will not empty
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Aug 18, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
How do you drain the dishwasher. the bottom is full of water.
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
heatman101
Jul 21, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
171 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
