Question about Maxtor Hard Drive
500GB BAsics External USB drive
Works OK on XP but when connected to the VISTA OS it seems to lose it's format and instead of NTFS it says RAW. If I move the drive to an XP machine it is fine.
What to do? What to do?
Mike
  • nienke_1981 Sep 15, 2008
    I have exactely the same problem! It was working fine on Vista at first.. then i tried it on a XP computer and since then it only works on a XP computer and not on a computer with Vista anymore.
    It does detect the external harddrive on my computer but when i try to go to it (open it) it says it's not accessibly. The weird thing is, when i'm running a program with which i download music and such (DC++) is DOES recognise the external harddrive and it DOES share the files that are on there..
Simple solutions are usually clever this is not. I just have to disconnect the power and when I reconnect the drive is recognised as fully functional. Eventually Maxtor will fix the driver. So far Vista has been fine and works very well with 4GB of memory and a fast processor.
Posted on Sep 10, 2008
  • 3 Answers
Simple Solution, Install XP on the Vista Machine...
Posted on Sep 09, 2008
How do i fix my usb flash drive .. it keeps going raw when i try to convert from fat32 to ntfs
When you say try to convert, you mean reformat from fat32 to NTFS? Depending on the size you may not be able to write it as a NTFS. Also, if you have anything on it you want to save, you need a raw recovery tool Squidoo has a good one.
However, if it won't let you format to anything and keeps reverting to raw, most likley your drive is damaged beyond normal repair.
Dec 29, 2014 | SanDisk Electronics - Others
Need restore my RAW file system back to NTFS without losing any hard drive files?
Still don't know what you can do to rescue your lost drive files right now?
OK! I have ever followed a video tutorial to resolve solve such hard drive data loss problems from here:
https://www.youtube.com/watch?v=S1F72QPGHm8
You can also check it and follow its steps to see whether all your files could be restored successfully.
In the future, to avoid such data loss troubles, always regularly save your drive stuffs on several places, not only on one hard drive.
Nov 07, 2014 | Seagate Computers & Internet
After I format my hardisk for several times and the file system still showing RAW. how to make it ntfs.
Install the drive on a working computer and access through disc management. that will allow you to initialize the drive and format it ntfs. Goto my computer right click select manage select drive management. This works on XP if you have other OS than search for disc management for your OS.
Aug 29, 2013 | Seagate Computers & Internet
Cannot copy more than 4gb file on a 500gb external usb hard disk
You have to change your hard drive from FAT32 to NTFS,because FAT32 limits the size of transferred files to 4GB. To do so ,go to Start,right click on Computer and select Manage. Under Storage click on Management.Find your hard drive in the list and right click on it and select Format. Under File System change the Answer to NTFS and leave the Allocation Unit to default. Click on Perform Quick Format if you want.click OK and confirm your OK with losing all data on the drive,and your done.
Regards Bill
Apr 14, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
RAW
Format the drive, right click in my computer and select format. Then select NTFS as the filesystem/format.
****WARNING!!!!***FORMATTING WILL DELETE ALL INFORMATION OFF OF THE DRIVE!!!!*******
Jan 06, 2010 | Iomega HDD External Desktop (32660) 80 GB...
I cannot copy files FROM my Western Digital 500GB
Check the file system of your hard drive. If your PC is recognizing it, check if its a FAT or NTFS. If it is NTFS then you have to reformat it using your Mac and choose FAT. Mac OS recognizes NTFS as a read only drive. If you plan using it with your PC and MAC you should format it using your mac and choose MS-DOS in disc Utility. You cannot format the drive using your PC Computer with a FAT file system because of the capacity. Only Mac can format it with a FAT file system.
Aug 23, 2009 | Western Digital My Book Essential 500GB...
External hard drive not recognised on my ps3??
Ok. Well this is easy! your hard drive is formatted in NTFS, ps3 wont recognize that. it needs to be fat32 find an XP machine not a vista machine.
download Swiss Army Knife and format the drive in fat32. you will loose ALL information in your external. you will need to back up anything you want to save and put it back after the format.
good luck!
Feb 09, 2009 | Maxtor Hard Drive
Unable to access external WD 500 Gb drive: "You need to format the disk"
It seems vista is the problem. On older operating systems the disk's work fine. My dis was formatted with vista and as a result showed exactly the same message when plugging it into a xp system. Back on the vista it works fine. The ntfs is native to win NT/xp there might have been changes in vista. Also do not use the firewire cabling, i had numerious problems until i reverted back to the usb.
Sep 19, 2008 | Western Digital My Book Essential Edition...
FRAGMENTED FILES IN DRIVE
Make sure ur hdd is RAW format.To change it from RAW to NTFS is dificult.Take that hdd and put on another pc and make it as SLAVE remove all jumpers and go to the MENAGMENT CONSOLE.Firs make it ad primary then delte .After that make it as LOGICAL DRIVE AND DELTE IT AGAIN.Again make it as PRIMARY AND FORMAT IT.I THINK IT SHOULD WORK.Let me know if u got help?
Dec 07, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor Hard Drive Logo
113 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
