Question about KitchenAid Dishwashers
Dishwasher Solenoid valve frequently opens and closes rapidly during the wash cycle
  • tudorhome Aug 31, 2008
    I'll send comment later!
    The problem with the dishwasher that we are experiencing is apparently associated with the level control. The level control is somewhat inaccessible. I would not attempt to pursue the problem further without a repair manual. So far, I have not been able to find a repair manual on the the internet. The Kitchenaid model number is KUDA220T.
  • 55 Answers
  1. could be a latch adjustment-- push gently on the doo when you hear the chatter. could also be something lodged in or near the level switch-located around the waterlevel--check manual
Posted on Aug 28, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Why does dishwasher let water in when not in use?
Tap water is routed to your dishwasher through a solenoid valve
this valve is spring loaded ,when the wash cycle needs water the solenoid is activated opening the valve and water enters when water is no longer the solenoid is deactivated and spring pressure closes the valve
in your case either some dirt has managed to stop the valve from closing completely or the valve has become in some way damaged
the quickest remedy is replacement.
Oct 13, 2014 | Dishwashers
Why does the door pops open when starting
I would check how level the dishwasher is. Might need to adjust the feet.
Aug 14, 2014 | Meiko FV 40.2 Dishwasher
2005 jeep grand cheroke limited with A hemi, been to the dealer more times then I can count, and still to this day the same problem. The service elect brake system light illuminates intermit and so for...
The braking force of the rear wheels is controlled by electronic brake distribution (EBD). The EBD functions like a rear proportioning valve. The EBD system uses the ABS system to control the slip of the rear wheels in partial braking range. The braking force of the rear wheels is controlled electronically by using the inlet and outlet valves located in the HCU. The HCU is a Hydraulic control unit. The HCU consists of a valve body, pump motor, and wire harness.
Did they check for DTC (diagnostic trouble codes) in the system? if so, what were they?
Accumulators in the valve body store extra fluid released to the system for ABS mode operation. The pump is used to clear the accumulator of brake fluid and is operated by a DC type motor. The motor is controlled by the ABM.
The valves modulate brake pressure during antilock braking and are controlled by the ABM.
The HCU provides four channel pressure control individually to all the front and rear brakes. Each of the four channels control the rear & front wheel brakes individually.
During antilock braking, the solenoid valves are opened and closed as needed. The valves are not static. They are cycled rapidly and continuously to modulate pressure and control wheel slip and deceleration.
During normal braking, the HCU solenoid valves and pump are not activated. The master cylinder and power booster operate the same as a vehicle without an ABS brake system.
During antilock braking, solenoid valve pressure modulation occurs in three stages, pressure increase, pressure hold, and pressure decrease. The valves are all contained in the valve body portion of the HCU.
PRESSURE DECREASE The outlet valve is opened and the inlet valve is closed during the pressure decrease cycle.
A pressure decrease cycle is initiated when speed sensor signals indicate high wheel slip at one or more wheels. At this point, the ABM closes the inlet then opens the outlet valve, which also opens the return circuit to the accumulators. Fluid pressure is allowed to bleed off (decrease) as needed to prevent wheel lock.
Once the period of high wheel slip has ended, the ABM closes the outlet valve and begins a pressure increase or hold cycle as needed.
PRESSURE HOLD Both solenoid valves are closed in the pressure hold cycle. Fluid apply pressure in the control channel is maintained at a constant rate. The ABM maintains the hold cycle until sensor inputs indicate a pressure change is necessary.
PRESSURE INCREASE The inlet valve is open and the outlet valve is closed during the pressure increase cycle. The pressure increase cycle is used to counteract unequal wheel speeds. This cycle controls re-application of fluid apply pressure due to changing road surfaces or wheel speed.
Nov 09, 2010 | 2005 Jeep Grand Cherokee
Dishwasher will wash but will not pump water out
There is a diverter valve that determines whether the pump re-circulates the water during the wash cycle or pumps it out to the drain during the drain cycle.
The valve is probably defective or possibly there are food particles which are preventing it from closing properly. The valve is usually built into the pump and has an electrical solenoid to open and close it. Check that the mechanical mechanism works freely and, with the bottom panel removed, check to see if the valve opens and closes when the dishwasher swtiches between the wash and drain cycle.
To check for food particles, you will probably have to disassemble the intake hoses from the pump and see if you can feel inside the pump intake for lodged food particles on the valve seal.
Jan 01, 2010 | Dishwashers
Water does not enter dishwasher during wash cycle
Make sure the under-sink valve is turned on. Then suspect the water solenoid valve under the front may have an open coil or stuck shut valve.
Dec 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishwasher does not completely drain after a wash. what do i do?
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock out plug at connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off
Jan 08, 2009 | GE Nautilus 24" Built-in Dishwasher
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Soap door won't open during wash cycle
Jan 17, 2008 | Kenmore 24 in. 16592 Built-in Dishwasher
Dishwashers Logo
73 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
