Question about Dishwashers
Door will not close. Looks like catch has gone into engaged position.
  • Kym Walker Oct 02, 2008
    I have a Bendix BDW54 and the door wont lock shut, so of course d/washer wont work unless you hold door shut, so may as well wash up whilst standing there!
  • 639 Answers
Dear friend,
ngfam at you service!
If its new your warranty is for 12 months!
Check the manual or download one at the makers site!
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Passenger rear door will not shut
open the door , place a philips screw driver blade under the latch catch and pull out at the same time as you press the handle release
in effect the door is already in the closed position before you try to close it
May 02, 2015 | 2010 Chevrolet Chevrolet HHR LT
Why does my dishwasher not close
Sounds like my daughter and her kids sitting on the door when its down. When lifted into position the latch no longer matches the"catch" It might require a little ingenuity to bend the door hinges back. it definitely sounds mechanical. Even a pro wouldn't let you watch how he bends that back. worse case scenario bite the bullet, call service tech, pay for labor AND parts (hinges or latch/catch) thinking again some of the older models (like cars) the latch is engaged and is waiting/depending on the opening of the door to change it's position. trying to shut it and a hard metal on metal clunck! might indicate a closed latch and not bent hinges... Good luck and give Fixya a bit of feed back~~~hope this helps---> S
Jul 29, 2014 | Dishwashers
How do i fix garage door that wont open or close?
You have to make sure the trolley on the drive engages with the catch on the door. You may have to lift the door to the point it will engage while you are running the trolley in the close mode. Check that the trolley latch is open and ready to engage the catch. There is usually a rope to pull on to do this.
May 16, 2014 | Chamberlain 950CB Remote Control
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
Door latch will not engage. Used WD40, and lubricating grease but still will not engage when trying to close the door
Sounds like someone might have engaged the latch with the door open.....that is....when you look into the latch (in the door) you might find that it is in a closed position ( the "claw like") metal part is down...as if it were closed and engaged on the receiver in the door jam. Take a screw driver...and while lifting up on the door handle, push the latch back up into the door. You should feel it catch in the up position.
Theroadisalover
Try to post back and let me know If I helped you solve your problem. It will help me with my rating....! Thanks
Jan 02, 2011 | 2004 Mazda Tribute
I have a Diplomat ADP8234 and the door won't close properly. It appears to be a problem with the catch. I also can't set a program but I think it might be linked to the catch problerm. Any advice
Hi, I have the same problem and when I use a screwdriver to flip the door catch to what looks like a closed position the dishwasher works fine but once finished the same problem is back until I reset the door switch again. Did you ever find a soloution please? Is it the door catch or the control board at fault?
Jun 25, 2010 | Dishwashers
Ariston dish washer door will not shut properly.
Check that something has not got wedged behind the top basket stopping it closing fully.If that is ok what can happen is that if there is something causing the door not closing fully ,when you try to close door to do a wash instead of the little hook actuator in the door switch fully engaging with the clasp on the body of unit,it closes down before it engages.It is like a finger hooking over say the top of your trousers.If you turn power off and get 2 small screwdrivers and carefully put them either side of the hook on door then try to bring it back to its open position.
Hope this helps.
May 17, 2010 | Ariston Technologies L63 Free-Standing...
The door will not close. It appears that the lock is in the closed position and will not allow the catch to close fully and engage. The m/c is mid cycle so I have switched off at the main socket
Check for obstructions, Check the door latch the latch may have moved into its housing,use a screw and position the door latch properly free from any obstruction,then try closing the door again..if not then you may need to replace the door.hope this helps pls do let meknow
Apr 05, 2010 | Neff Dishwashers
My car's trunk wont lock or close at all. What do I have to do take it to a auto shop or what? I dont know the cause or maybe the lock is broken.
Just like any door that closes, the trunk latch is comprised of two parts: one is a mechanism or latch, the other is a plate or pin that the latching mechanism catches it on. At least one of these is adjustable, and most if the time, both are adjustable. Check either of these parts, and see, if you pull or tug on them, if they move or wiggle. Chances are that one has worked itself loose, and needs to be readjusted. Or, you could have some debris or foreign particle in the latching area preventing it from fully engaging the catch. Another scenario is that somehow your latch has become "pre-engaged" and therefore will not catch, if it is not open to receive the counterpart.
If none of these apply, then check the latching mechanism, see if you can get it to "latch" by hand, so you can see if maybe a spring or something has fallen away. Then again, if it is man-made, it will break eventually, maybe that's the case here.
Hope this helps.
Jan 08, 2010 | 1995 Toyota Camry
Indesit dishwasher
I had the same problem, so I took the door apart as explaned above, found it was gunged up with residue from the washihg cycles. Gave it a good clean, while the part was disconected of course, and hay presto! the door works like new again.
Jan 06, 2008 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
Top Dishwashers Experts
