Question about Freezers
Hotpoint FFA74 Fridge Freezer - Freezer High Temp Warning Light on.
I have a problem with my fridge freezer, The high temperature warning light for the freezer comes on all the time, the freezer freezes things like ice cubes but doesnt freeze other food properly, ice cream is always really really soft for example.
I keep pressing the fast freeze button as a quick fix but really need to get it sorted! It's only just over 2 years old, Ive never moved it so I dont think it could be damaged by being knocked etc. Please Help!! Many thanks :)
  • 3 more comments
  • Anonymous Aug 29, 2008
    freezer high temp keeps coming on
  • studleyMc Sep 20, 2008
    I have the same problem. The light comes and goes all the time!
  • bridge113 Oct 02, 2008
    I have the same problem after 2 years.I have defrosted the freezer manualy and found that the problem seems to relate to the draws being pushed foreward by the freezer plate behind them.this in turn creates a bad seal around the door,hence the temp warning light comes on.I have removed several draws and the freezer works now,but the problem isn't solved.If any one knows of an answer I would be keen to know!
  • scooper28 Nov 17, 2008
    I don't think I have any probs with the drawers and the door..my friend suggested it could be the fan?
  • Anonymous Mar 06, 2009
    Freezer High Temp Warning Light.
    I too have had to take two drawers out, but his has not rectified the problem for long. My fridge started doing this at 2 years old.
    Am now going out to buy a new one, and it won't be a hotpoint appliance.
The
Posted on Nov 03, 2008
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
My FFA70 fridge/freezer is causing my circuit breaker to trip, when I reset the circuit breaker the fridge/freezer will work again, but both the red bight temp warning light and the freezer defrost light...
kevinmdoyle... Hello and welcome to FIXYA,
Yours is a UK model... so I (usa) can't help you
on SPARES (motor start capacitor) ... however
Circuit breakers do go bad...!!
(easiest & cheapest to check first)
MUCH Easier to test the idea than you would imagine:
- Shut OFF your main breaker.
- Open your panel & swap the wire with an EQUAL breaker
- Tag the wires (to restore when finished trouble shooting)
- Restore the main breaker (wait & see)...
and don't forget to clean that CONDENSOR
per owner manual instructions.
If the failure persists... RESORE the BREAKERS.
and
HOPE it is the START CAPACITOR on your compressor.
Carnac the Magnificent
Jan 15, 2018 | Hotpoint Freezers
Temperature warning light came on. Removed
dear sir/madam
i think its tempretor sensor /thermostat problem please try to find thermostat needele and keep in right position , and check its tempretor satting if it,s need to reset please reset it . i hope after that it will working good. if not please try to contect your freezer maintanance perssonel for repair/reset your freezer .
hope answer the question.
thank you
please vote!
Jul 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Servis fridge freezer
It may be that the temperature of the unit is not yet up to temp.The flashing light will indicate this.Warning the user the unit is not ready,or up to safe temp.. Let the unit run to catch up,since you just started it.
Nov 30, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Hotpoint combination 8591
Look like your refrigerator ran out of freon.
Nov 26, 2007 | Freezers
Freezers Logo
3,599 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
