Question about GE Dryers
Ge dryer the dryer is working but it will not turn off when the timer runs out it will when you open the door what could it be
  • 706 Answers
The door is interlocked to stop the drum from turning and.or causing an injury to anyone opening it.. The timer is the control system that switches the drier and heater on to dry clothes but it does that by energizing a relay /contactor.. You probably have a bad relay or your timer is bad and not de-energizing that relay to stop the cycle... If you provide specific model number of your GE dryer.. that might help in diagnosing your problem...
Posted on Aug 29, 2008
SOURCE: whirlpool dryer problem
dryer works but does not heat up
Posted on Aug 11, 2008
  • 734 Answers
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
  • 40 Answers
SOURCE: My GE Dryer model DWSR483EA1ww will not stop & doesn't dry quick
first thing you should do is check the flow of your vent, a clogged vent can cause all your problems check it outside while the unit is running you should get really good flow compare it to the flow of the dryer with the vent hose off the dryer completly. they should be fairly close or just run it with out the vent hooked up to the vent if you have an electric but not with a gas dryer
Posted on Mar 09, 2009
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
  • 1122 Answers
SOURCE: Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Posted on Apr 22, 2009
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Dryer won't start when you turn the timer on
Check the house fuse or circuit breaker to make sure power is on. Check to see if the door switch is working. Use a small screw driver or stick to move the switch lever with the door open.
Oct 16, 2009 | GE Dryers
Buzzing noise when i turn the timer switch
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
G.E. electric dryer will not run, when you turn the switch to start it only hums. What could be the problem, it is only 3 years old. Thank you
First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be seperate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safteys that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Aug 27, 2009 | GE Dryers
Timer Continues to run when dryer is shut off
the timer keeps on going even if you open the door this is normal
Feb 18, 2009 | Dryers
Timer motor keeps running on dryer
sometimes as a timer gets older the timer motor will get a little loud. timer motors run even when the door is open. if the timer advances to off and everything works fine you don't need to worry about it.
Nov 19, 2008 | Dryers
Dryer timer was working
because there is a door switch that would turn your dryer off because of safety issue.
tnx 4 using fixya,
Oct 04, 2008 | GE DSKP233EWWH Electric Portable Dryer
Dryers Logo
126 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
