Question about HP iPAQ hw6515 Pocket PC
VPN connection problems!
Hi, I'm trying to get my hw6515 to connect to our cisco 3005 vpn concentrator via pptp over gprs without success. I can connect successfully via laptop & xp via pptp but the ipaq just won't connect. Nothing relevant in the concentrator logs. The ipaq just connects gprs, and sits there saying "Connecting to x.x.x.x" after a bit it gives me "VPN server problems ... bla bla bla" Does anyone have information that could help me get this going? Thanks in advance
  • 450 Answers
I am not real versed on VPN connections but the only way I was able to connect to my company's Cisco VPN using my Ipaq was with this program. The whole thing went very easily.
Posted on Sep 08, 2005
How to setup VPN on iPod?
connect to WiFi.
Tap General>Network>VPN>
you can try these settings I've used before:
Add VPN Connection. chose PPTP.
Give it a name under description.
Encryption Level:Auto
Send all traffic: ON
Proxy: Off
Here's the part that differs from the VPN I personally set up.
Server: enter the IP address of the VPN Server. this is specific to you, as to what server you want.
Account: Enter username and password to log in. If this VPN is for school, it would be your school username and school password you normally use.
The VPN at my school worked when I connected to their wifi and then turned on the VPN. for added information.
Jan 21, 2015 | Apple iPod Audio Players & Recorders
How to connect my MSSQL server through VPN by using PPTP
192.168.1.X is a local ip address ,, i trust that thhe vpn is in seperate places and is done with the wan ip over an internet connection?????
OK maybe the problem isnt on your side but the main office building,, when connecting , have someone looked for repeated attemps to connect by observing the fire wall,, if it appears to be blocked byu the firewall simply diasable any and try it out.. If it works then all you need to do is set the firewall correctly..
I was reading the ip address in your original post and those are local address,s are you certin the VPN is correct ???? did you use the correct STATIC IP ADDRESS ASSIGNED BY YOUR ISP??
Jan 20, 2008 | Cyberguard SG300 (00852503000366) Firewall
Belkin n150 cisco vpn
hi - I just had a tough day trying to connect N150 to my company's VPN, and after a long struggle found out that Belkin N150 does not support the VPN connections. simply upgrade it to N300 and you would be fine.
Jun 08, 2012 | Belkin Connect N150 Wireless Router...
Receiving the following error while trying to connect to VPN using F5 network VPN adapter.Error 721 - the remote computer did not respond
use the router's public IP address for PPTP requests, instead of one of the other public IP
addresses our ISP assigned us, and simply forward PPTP (TCP 1723 & IP 47)
requests to the internal servers. Therefore, the only difference is that I
am using a pingable IP address which happens to belong to the router instead
of using one of the public IP addresses I have NATed. For whatever reason,
this solved our problem with connecting to the RAS server. We no longer have
to retry up to 6 times to successfully connect
Second , See if port 47 is blocked....
Let me know if this works
Mar 08, 2011 | F5 Networks VPN Adapter
Cannot get PPTP VPN to connect via Westell 327W (Verizon DSL)
Is the VPN server that you are trying to connect behind a firewall?
Jul 18, 2009 | Westell Wirespeed VersaLink...
How to connect to my PIX 501 and use Windows Remote Desktop?
Here's a real simple problem to your remote access problems.
Go to:
Sign up for a free acct, download/install their free software on your Server.
Now go over to your laptop, login to your new logmein acct.
In the next page, you'll see your Server listed. Click on it - follow instructions to connect.
This will tunnel through whatever stuff you have on your network!
Trust me - esp. in your scenario, this is *by far* the *simplest remote connect you'll ever perform! And it just .... works! Everytime.
Mar 16, 2009 | Cisco PIX 501 Firewall
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
HP iPAQ hw6515 Pocket PC Logo
142 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
