Question about Video Game Consoles & Games
My handheld dvd player isn't reading the disc-they just spin really fast
    Problem Solver:
  • 14 Answers
Spray an small drop of safe window cleaner onto a Q-tip. Clean the laser lens carefully and then use the other end of the Q-tip to dry it. Use compressed air on and around the laser lens (do not blow on it). Clean your DVD disc and try again. If it fails again, try using a CD, if it will play a CD and not a DVD your optical pickup assembly is defective. If the CD wont play at all, your optical sled or spindle motor and/or drive is defective.
Most cases if cleaning doesn't fix it, it's cheaper to replace the entire DVD player. All portable DVD players are junk, regardless of brand.
Posted on Jul 18, 2011
SOURCE:
Detrola cd player spins too fast
Did you undo any leads when you changed the belt, are they in the correct position, it's spinning fast because it can't focus.
Aug 29, 2014 | Televison & Video
Sims 2 bon voyage stops installing at 57%?
um-mm...some disc are really thin and have trouble reading the disc because it is spinning far to fast. This usually happens far to fast. You could also get a cleaning disc, that they usually have for DVD player, I don't know if they have one for the computer or not, but it would be great to look into. Also, one new thing that people aren't looking, because this happened to my DVD player, you see, my DVD player kept saying wrong disc, and it was because a battery had a whole in it, and the corrosion of the battery melted and destroyed the Lazar, as well as flowing into the jack. so I had to get rid of it before fixing it. Now, it probably can't copy the file, because your computer needs its hard drive updated, as well as the AGA Graphic memory, I had trouble with a game one because it didn't have enough graphic color for 3d flash games. So check for that. Take care and good luck.
Sep 18, 2012 | Electronic Arts The Sims 2: Bon Voyage
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
When a DVD is placed in the player to play, the reading on the screen is "No Disc" and nothing plays.
Check the motor if its spinning or not.If it isn't spinning fast enough that you need to lubricate the motor from the underside so that the lubricant doesnt go on the lens.But if its spinnig fast enough that maybe the lens isnt picking and needs cleaning or replacing..Good Luck
G..
Aug 10, 2011 | Mintek MDP-1760 Portable DVD Player
I have a Sony DVP-NS57P DVD player, The disc doesn't spin unless I give it a light touch; then it spins, reads and plays fine. If I stop it, eject it and reload it, the same thing happens again and I...
Problem seems with spindle motor that needs little bit lubrication of WD40 contact cleaner spray.
Let me know if you are willing to take apart dvd player and have WD40 spray.
Thanks.
Jul 29, 2011 | Sony DVP-NS575P DVD Player
Everytime I put a disc in I get an error saying no disc
Does the disc you insert are original..If not is isn't posibbles for your dvd player to not recognize yor disc cause most of the branded dvd players like you have didn't read pirated disc..but if the disc you insert is original. Try to clean your dvd player using a dvd disc cleaner.
Jul 17, 2011 | Philips DVP5982
Brand new! Stopped reading discs, won't play. Power to both screens, and the DVD spins really fast, but never reads. Tried several DVDs, so we're sure it's not the disc. Less than 6 weeks old. What could...
I would take it back to the store, there is a malfunction in the laser pickup assembly, and there is nothing can be done to correct it, a manufacture defect.
Feb 03, 2011 | Disney D7500PDD Portable DVD Player
Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Aug 13, 2007 | Toshiba SD-P1400 Portable DVD Player
Video Game Consoles & Games Logo
69 people viewed this question
Top Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
