Question about Sony STR-DE445 Receiver
Receiver str de 445
I'm have problems getting my 4 speakers, centerpiece, and sub working. I must have wires going into the wrong spots. Anyone have any ideas or suggestions for this?
  • Anonymous May 18, 2009
    i can get it to play in 2 channel or front center and sub but i cant get the rear to work. that is to say i cant figure out the settigns to select it. its not an option in the mode list.
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
STR-DE445
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 28, 2008
Trying to get my 5.1 channel input to work on my sony str-445 receiver
Maybe it won't work because you have the inputs confused with the outputs.
Nov 08, 2013 | Sony STR-DE445 Receiver
Helo ! I need to know why the subwoofer is silent when I connect it to my receiver-STR DE 475 . Plus , the sorround does not work . When I push the bottons , I either get the centre with the front...
Have you looked at the manual? There are procedures for adding a sub (which is NOT necessarily assumed to be there) and assigning bass to it.
http://www.retrevo.com/support/Sony-STR-DE475-Receivers-manual/id/387bh949/t/2/
Then there's the unidentified sub's manual and requirements to consider.
Sep 01, 2011 | Sony STR-DE475 Receiver
Sony str de 475 ?? is appear 'protect' on screenboard and can not listen anything
The message appears usually when the wiring is wrong (short circuit) or the speakers are defective or their impedance is too small for the amplifier's output (for instance 4 ohms speaker connected to an 16 ohms output). First, check your connections.
May 15, 2011 | Sony STR-DE475 Receiver
No sound from sub woofer
sub may be blown up, on protect, sub could be hooked up wrong. Did it work before and if so were all the wires hooked up the same? check to see if its being overloaded by blown speakers, check all speakers one by one, check your amp sub output with another speaker, I have had this problem form hooking up wrong.
Hope this helps...........
Apr 13, 2010 | Sony STR-DH500 A/V Receiver
I am thinking of buying a SONY STR DE725 (QS Series) AV receiver. I alreay have a set of home theater speakers with 5 x 80W 4 ohm and and active Sub-woofer (200W). I am wandering whether the receiver...
Yes, it will support a powered subwoofer.
If your existing speakers are from an all-in-one Home Theater in a Box and they have molded connectors you'll have to chop them off to make the ends bare wire and determine which is plus and which is minus on each. Loads of 4 ohms may present a problem at high volume levels.
Take the rated wattage of the sub and other speakers in an HTIB with a HUGE grain of salt. They plays numbers games with th low impedance and the allowable distortion levels to get the results they publish.
For all anyone knows, the speakers and their original electronics may have been designed to operate together to yield adequate performance (like Bose does). Breaking that pairing may give unpredictable results and risk of damage to the speakers or the new receiver.
Feb 18, 2010 | Sony STR-DE725
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
I need help my sony str dec 445 keep flasking the protect on the display
first check for any loose speaker wire in the back as this will cause the unit to go into protect mode if the bare speaker wire is touching, if thats not the case then there is a problem with the unit internaly and would be hard to tell whats wrong with it without looking at it.
Dec 11, 2009 | Sony STR-DE445 Receiver
DE 445 flashes "protect" and sound goes off when loud noises play on DVD
Check your speaker connections at the back of the receiver and at the speakers. You have a short. If you don't see anything obvious, disconnect your speakers at the receiver and play a dvd and turn up the volume. If it stays on, you have a wire or a speaker problem. If it cuts out , you have a DSP chip problem. Reconnect speakers one by one and test each speaker until it cuts off or you have fixed the problem. If you still have issues, post a comment and I can help you some more.
Aug 07, 2009 | Sony STR-DE445 Receiver
Sony STR-DE445 Receiver Logo
1,294 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
