Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Check Document The error message is "Check Document"......There is nothing in the document feeder, nothing in the glass....I can't find any paper....I believe one of my employees tried to feed a card stock through the feeder and possibly it got stuck and she pulled it out...Not sure, just guessing.....Machine will not work at all....Can turn on, but it just beeps when you try to copy something....
    Problem Solver:
Look at the sensor arms on the feeder cover...open feeder,and take it off from the sides..there are little wings that pop out of socket, and look at the black toggle arms... one most likely is dislodged...make sure they all toggle freely...ckeck the one towards the bottom first...if you have to , take screws out and pull cover apart to re-insert toggle arms....
Posted on Dec 12, 2008
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Document in ADF error, however there are no
I'm having the very same problem. No paper was ever stuck and the first time I tried to scan a document by laying it on the glass, not even through the feeder and it did this, and just like with you now it won't even print. Apparently this happens a Lot. I sure wish I would have seen these issues before I bought it! I wish I could help you out, but at least you know you're not alone.
May 02, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Hp 3050 scanning error message
Good day!Try to check the feeder if it has paper on it..then try on and off the printer until it holds normal status..
mastergani
Mar 29, 2010 | HP LaserJet 3050 All-In-One Printer
How do I clean document feeder? It is putting
If it is just puting lines on the copies ONLY when using the feeder here is all you need to do to clean that thoroughly.
Get a phillips screw driver. Lift the document feeder, you will see the "seal glass" about 1 inch wide on the left side. Remove the 2 silver screws, One on each end. Lift that glass up and out. Lay it on a white piece of paper. Take some alcohol and a regular piece of copy paper and clean that until you see nothing on that glass by placing it against the white paper. Get every little speck off. Then put the glass back in.
If you want to clean the entire scanner that is a different procedure all together. Let me know .
Feb 10, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Copies run through feeder distorted
Document feeder Paper feed rollers should be cleaned with alcohol, blow out the document feed area with compressed air (computer duster), check feeder for bits of paper, post it notes, and signature flags. Clean glass, check for sticky areas on the glass.
Hope this is of some help.
Ed
May 12, 2009 | Toshiba E-Studio 3511 Color Copier
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
401 people viewed this question
old marine
old marine
