Question about Avanti DG241BS Stainless Steel Gas Kitchen Range
Clicking igniters the burners keep clicking even when they are off. 3 of the burners light but the front right burner dosn't. the clicking continues even when 1 of the 3 burners are lit. I have unplugged the stove to stop the clicking, but I need help FAST!
  • robynice Aug 28, 2008
    I was asking about a gas range, not a dryer.
  • rssgmbl Sep 23, 2008
    I have the Avanti DG20CSS gas range which is having the same ingiter problem and A&E Appliance does not work on Avanti products. The Avanti company gave me a local repair service, but they do not work on Avanti anymore. Am I really stuck with the only option being a random call in the yellow pages for a product no one knows about. Thanks, rssgmbl
  • 639 Answers
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
CALL SERVICE 24/7 HERE,
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
  • Neil
    Neil Aug 28, 2008
    Dear Friend,
    Sorry about the mix up when I wrote dryer instead of Range in my last letter!
    Your clicking sounds like the igniter's are malfunctioning and are in need of replacement!
    This can only be done by service!
    Bless you,ngfam1
Jenn-Aire Model CVG4380 gas stove top. Why doesn't igniter work?
Under your knobs are burner switches, 3 of them are the same, so this will be a hit and miss on getting them but possible. Each burner should trigger the ignition system. This will be needed to be inspected to find out which one needs to be replace. If you get the right person to look over the unit they could tell you if it can be repaired. I worked on one about 3 years ago and it worked out fine. Good Luck and I hope this helped.
Apr 11, 2016 | Kitchen Ranges
Igniter misfire
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner won't light
hi gud day,i think the sensor is we have problem is hard to repair in ur own,try to call the person have expireince for repair that unit, or ur igniter ligther have damage like small broken if u hear have click is ok but much better to check the igniter coz the broken igniter is not directly spark in the burner that why is not light.to check if remove the burner base cover then see if the igniter like a small niddle color white,turn the knob to click the igniter then see it wer the spark directly if u not see it means have a broken igniter.
tns gerbee
May 26, 2009 | Amana AKS3040 Gas Cooktop
Burners continue to click after ignite
I would say it was the switch , do the others do the same thing?
Apr 14, 2009 | Viking VGIC365-6B Gas Kitchen Range
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Open Questions:
Avanti DG241BS Stainless Steel Gas Kitchen Range Logo
244 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
