About 90 % of the time when i put a disc in to play on my logik stereo... it say;s reading for a little while and then disc err.... can you please help ?!? Thank you
  • 4,234 Answers
The unit can recognize that a disc is present but is having difficulty reading the table of contents (TOC). A simple cleaning using a cotton swab and alcohol of the lens will often fix this problem. Try that and update this if you still are having problems.
Dan
Posted on Aug 28, 2008
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
My logik lpd850 portable dvd player is turning on but doesnt seem to play any discs it just keeps reading no disc any solutions please.
the fault is obviously from the laser (lens) of your player. The lens is very weak such that it cannot load/read data on discs.
The best to do now is to replace the lens and your player will play all discs again.
Take care.
Jun 04, 2010 | US Logic DVD800P Portable DVD Player
My radio wont play Cd's. Everytime I put in a cd,
Your CD player's lens is not working, meaning either if you can open it and change the lens or install a new stereo, see which solution is cheaper.( you can find stereos for around $35) . Good Luck
Feb 09, 2010 | 2001 Pontiac Grand Prix
Hi i have a sony car stereo that plays the radio only!
what is happening on the display is the laser reading the disc if its not reading the disc your cd player is faulty more than likely the laser is either dirty or had its day,make sure there is compatible music data on the disc,also check all the sound options on the stereo.
Aug 25, 2009 | Audio Players & Recorders
CD player says error and spits discs back out repeatedly
If cleaning didn't help,then replacing is the way to go.You can go to a local stereo shop and see if they can fix it easily.they might know the trick on doing it.It's worth a try.Don't go to Best buy.I know you have seen one as you were driving around town,just pull in and see what's up,They may have fixed one as the same as your Nissan.
May 30, 2017 | 2000 Nissan Sentra
Cd player comes up with err message
Oh, i had this problem several times... look, the best answer that i can give you is to buy a new one, there's sony's cd-players that are great, me and my father have. now, if you want to stay with this cd player just insert the cd several times until it will play. but again, you better buy a different one.
Jun 16, 2008 | 2000 Renault 181
Logik LM101DU
I had the same - turned the power off overnight and the unit seemed to 'reset' itself and work. Davep.
Mar 10, 2008 | Audio Players & Recorders
69 people viewed this question
 Grubhead
Grubhead
