Question about Sony Ericsson K300i Cellular Phone
Display Problem when i change my display it turns opposite direction
    Brigadier General:
  • 7,752 Answers
You may not have it in poperly so dis-assemble it and put it together again or replace the LCD once more
Posted on Sep 21, 2008
Our Sentry Safe cannot open even we have the key and opening numbers.
Sentry has a web site try that. If I remember my trouble was the number of turns. Seems like it has 4 turns past the 1st number, 3 turns opposite direction on 2nd number, 2 turns the opposite direction 3rd number, then turn dial opposite direction til it stops. Then you twist Handel. Does this sound like your procedure?
Aug 01, 2017 | Miscellaneous
Changed plug wires now cant start
Check for the right location by turning crankshaft till at zero degrees on the pointer scale-the timing scale. Then look at rotor position: should be either pointing to No. 1, or will be pointing directly opposite if you are on the exhaust stroke (TDC) of No. 1. Turn the crank one revolution, and come back to the zero mark. If rotor was pointed opposite before, it should now be directly at the number 1 plug wire tower.
Jan 03, 2013 | 1990 GMC Sierra
Im using Panasonic KX-mb773 is displayed CHANGE DRUM.I NEED DRUM REPLACEMENT CODE. Pls help me fix this problem
Take out the drum unit ,you will find a usually white screw on the left side of it , insert a screwdriver and turn to the max to the opposite direction (anti clockwise I believe ) till the end, insert the drum unit back into the printer. It will determine that it is a brand new unit. Good luck.
Oct 11, 2011 | Office Equipment & Supplies
Does my 2001 Jeep Cherokee Sport 4.0L 4WD have a
Easy way to find out is to lift both rear wheels off the ground. Have someone turn one wheel and someone hold the opposite one if they both turn at the same time and in the same direction then you have a posi rear. If only one turns or the other turns in the opposite direction it is an "open" rear.
Feb 07, 2010 | 2001 Jeep Cherokee
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Err 22 keeps displaying on control panel on one treadmill and on another err45 ..... Any answers? Plus some treadmills same to just trip, have to keep switch them back on!
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started
Possible Causes 1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. 2. Drive motor brushes are bad. 3. The speed sensor position relative to the speed sensor target is incorrect. 4. The speed sensor potentiometer adjustment is incorrect (when equipped). 5. The speed sensor is inoperative. 6. The lower PCA is bad. 7. The lower PCA to upper PCA interconnect cable is bad. 8. The upper PCA is bad
Error 45 :The lift control system has detected that the lift is moving in the opposite direction of the issued
Possible Causes 1. Lift Motor hysteresis. 2. Bad lower PCA
Possible Remedies 1. This error would typically happen when the lift was already in motion (typically downward) when a lift command in the opposite direction (lift up) was issued. Some motors exhibited a very long turn around time and the lift motor would still be moving in the original direction (downward) while the control system was attempting to move the lift in the opposite direction. If the error 45 condition is persistent, replace the lift motor. 2. This is a very rare condition, if the lift moves in the opposite direction of the issued lift command, replace the lower PCA lift command.
Feb 02, 2010 | Precor C954i Commercial Treadmill
Directions to change day and date on old bucherer automatic watch
Try this: pull out the winding crown to the first click and change the date. Memorize which way the crown turns to do that. Now turn the crown in opposite direction and the day should adjust.
This solution wrks for most of the makes.
If this doesb't work - submit the make, model and all the writings on watch caseback.
Mar 14, 2009 | Watches
The ball turns in opposite direction.
You have a 3 phase unit, it can run opposite direction if the main feed wires are not correct for the motor wiring. If you simply swap any two of the main electrical feed wires it will run in the opposite direction. This should correct your problem now. Enjoy.
Dec 29, 2008 | Hobart D300-6036 Mixer
Sony Ericsson K300i Cellular Phone Logo
20 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
