Im having a problem boting my ipaq h3970,
it will not load at all, i think there for the problem might be with the bootloader. i have tried a reset but that did not change anything.
how would i go about correcting this problem
any help
Have you performed a full reset rather than the normal reset? It might help but you will loss any settings you have so be warned.
Procedure as follows:
1. Press and hold the two outer buttons on the bottom of your iPAQ.
2. While holding down those buttons, use the stylus to press the reset switch for at least five seconds. The screen will go blank.
3. Connect the iPAQ Pocket PC to the AC adapter.
4. Run through the Setup Wizard to reestablish system and calibration settings.
I hope this helps,
you need to install the pc suit of the device on the system.use the cd that comes with it to do that.But if dont have the cd goto http://google.com enter the model of your device and add pc suit at the end then click search download and install
So you can just copy a jpeg file over to the IPAQ and then click on that file and it will display it.
It's best to resize your photo down to below 100KB before you copy it to the IPAQ.
did you install the following:
"iPAQ H3970/H3975 SD Card Driver Updates
version 1.1 (27 Oct 03)"
SP25681
- Resolves performance issues with SD memory card.
- Resolves undetected SD memory card.
- Resolves lockups due to SD memory card.
