I programm trying to uninstall a program (quicken) to install a newer virsion and the older one will not come out
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Quicken is one of the "friendlier" applications. Unless your hard drive is full, you don't need to uninstall the older one to install the new one. I suspect the uninstaller has failed. Without more detail, I can't help there. However, Quicken will install the new one and may even attempt to uninstall the old one itself. Regardless, you should be able to just install the new one and have it locate your existing data. Don't just delete the directory as you'll probably delete your data as well.
Posted on Aug 28, 2008
Program has to shut down as soon as I sign in
You will need to uninstall and re-install the program. Open Control Panel, Programs and Features. Find Quicken on the list and uninstall it. Reboot the PC and re-install Quicken. This should solve the problem. If not then there is another program on the system that is causing the problem and will require further investigation.
Jan 31, 2018 | Intuit QUICKEN 2014 DELUXE
Running windows vista service pack 2 but quicken 2014 won't open
One solution would be to run it pretending your Vista is XP. I have seen it done but as I have no Vista machine, I cannot tell you the steps. Search for running Vista in XP mode - once you have managed that, try installing the software.
The second solution would be to open a virtual machine on Vista and running that as an XP machine. Again, I have seen it done.
Try the links I have added below.
The problem I had was with Quickbooks, not Quicken, but the principle is the same and worth a try. Good luck.
Use XP Compatibility Mode in Windows Vista Win7 Vista Windows XP Compatibility Mode in Windows 7 and Vista
Feb 13, 2014 | Intuit QUICKEN 2014 DELUXE
Can I download quciken 99 delux and read back up files in windows 7
Typically with Quicken... a NEWER version of Quicken will automatically upload back up files from OLDER versions but not visa versa.
Hope this helps.
Nov 25, 2012 | Intuit Quicken Deluxe 99 for Windows...
Is Quicken99 compatible with Windows 7 and/or XP?
The best way to install older versions of Quicken on Vista or Windows 7 is to run the setup program through the Windows Compatibility feature:
In Control Panel search for 'compatibility' that will bring up an item 'Run program made for previous versions of Windows'.
Select this and step through the process which will eventually show a list of all programs loaded on the system.
Select the first option 'Not listed'. This will then prompt you for a location of the program.
Click 'Browse' and select the location of the Quicken install program (either CD or disk).
Once found, select the Quicken install program and continue. This will the suggest that the installer run in XP mode. Click 'Next' to run the installer.
Aug 09, 2010 | Intuit Quicken Deluxe 99 for Windows...
I bought Quicken 99 (basic) when it came out. I installed and re-installed it succesfully up to Windows XP until this year. This past month the icon dissapeared from my desktop and this past week, when I...
You could search the WWW for that file ... I think your best course of action is to get a good back up - both on a hard drive and on a cd or dvd of your quicken file. Save your file under a second name also (see below). Get 2010 version, which they started advertising to Quicken users about 2 weeks ago for $78.00. Load the software then tell Quicken to load your file.
BE ADVISED - the copy of your file on your hard drive will be over written when it converts to the new Quicken. That is the reason you save as another name. The new copy will not run on your Quicken 99 - however, you still have 99, right? and you have the copy under another name to run on that, right?
So you should be in good shape either way.
I think your real 15 year record is that you used it for so long!
Tell me, did I just answer another Quicken question for you here?
Thanks
a
Jul 17, 2009 | Intuit Quicken Deluxe 99 for Windows...
Quicken Deluxe 2009 stopped working
your quicken deluxe 2009 is very OK... i think your system vista 64bit is the problem.. is there any other way that your 64bit vista is updating? if you try to use your quicken deluxe and it might works there.. so this time you are going to system restore your vista 64bit and back the recent checkpoint that quicken is run normally...
Jun 19, 2009 | Intuit Quicken Premier 2009 for PC
Printing check from Quicken 2009 Deluxe
All Printers have this issue printing from quicken you would need to download the older version of quicken from oldversion.com
Then uninstall the new version and install the old version.
all lexmark/canon/epson/brother/hp.....printers have this problem with the new quicken.
Or try calling in to us at 1800-474-6836 and provide us with a remote session with your computer we may be able to fix this issue with a basic driver.Let me know if you have connected the printer thru usb or ethernet and I will give you a resolution that works 70% of the time with the new quicken
Jun 16, 2009 | HP OfficeJet 6310 All-in-One Printer...
I have reinstalled quicken deluxe 2000 after my hard drive crashed.This has been repaired,All The previous quicken accounts programme has been stored on the d drive. I do not know which quicken files to...
In the C drive Navigate to View menu and choose option "Details"
Now you can see the Created Date for specified files so that you can check which files are older / newer
May 27, 2008 | Intuit Quicken Deluxe 99 for Windows...
Quicken 2004 Installing on Windows Vista
i got new window vista cd orginal to upgrade previous version
window xp that i download also use orginal cd for installation.
but my winamp player,webcam,live messager & mail was stop working when i double click on the icon.
i also try to uninstalling & install back,but still same problems
show stop working.......prompt on the screen.
can you tell me why and how could i troubleshoot this problem or repair it please.
Jan 19, 2008 | Computers & Internet
Re-install of quicken
go to registry and search for quicken
delete every reference to quicken
and delete the folder it was in and
shotcuts Then try a new installation
Nov 12, 2007 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
