How to open the back of a
I want to open the back of my "Balay" TS755 washing machine to get a piece of plastic that got inside, but I could not find any screws. Can you help please?
  • 639 Answers
Dear friend,
ngfam at you service!
Call service or face more problems !
If its new your warranty is for 12 months!
If the dishwasher is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
    President:
  • 1,462 Answers
Don't know this appliance but usually the easiest way to get objects out is to remove the heater
Balay washing machine door wont open
We were staying in a holiday apartment and couldn't get the Balay washer/dryer door open on dryer cycle. Tried all the previous solutions and none worke. my husband turned the power off to apartment at fuse box and the door clicked open after a couple of minutes.
Feb 18, 2014 | Washing Machines
Front loader washing machine inside hard plastic bar broke off
there are several kinds of plastic cement..everything from superglue to plastic pipe cement like plumbers use..available at most hardware stores..even model glue..I would try one of these before pitching the washer..you nmay be able to screw it on using stainless steel sheet metal screws also..
Jan 15, 2014 | Kenmore Washing Machines
Error E5 on Balay ts7210 washing machine
This is a door lock problem can be door lock or main PCB
Dec 20, 2013 | Washing Machines
Why it doesn't spin
almost all washing machines have a special switch to turn off or don't let spin when door is open. If machine 'thinks' that door is open, won't spin. "" Danger, Will Roberson...Danger..."" If you don't know what U are doing, please get help. An open switch looks like door is open.The switch is INSIDE the body of washing machine, ON the door is a plastic piece that pushes the switch lever in. You have to place 'jumpers' across the contacts on switch,shorting switch and turning machine to spins cycle.
Feb 16, 2013 | Washing Machines
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
My daughters washing machine of 3 yrs old keeps stopping and flashes F 18
F-18 means the pump is blocked. When the machine fails, there may be an "electrical" smell as the motor has laboured. This is normal. Clean on bottom right corner and you should be fine..
Open flap at the bottom righthand flap.
Keep big bucket handy for water.
Remove clear plastic attached to black tube (slowly)
This will empty water from washing machine.
Once empty - no water coming out from washing machine then open big opener next to tube and remove any objects inside( coins, buttons and such)
Put back clear plastic filler firmly inside as before.
Close big opener next to tube.
close flap
Turn machine programe knob to DRAIN.
Start washing machine.
Should do the trick....
Good luck
Apr 01, 2011 | Washing Machines
Brother MFC-7220 says "close back cover" but it's closed
Have you tried this solution by joefishny:
Turn the machine around so that you are facing the back. Open the back cover. Pull down the second
smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the
length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of
plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Mar 28, 2009 | Brother IntelliFax-2820 Laser Fax
Mfc-7220 Back Cover Open
This one made me crazy, but I finally figured it out. Turn the machine around so that you are facing the back. Open the back cover. Pull down the second smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Jan 03, 2008 | Brother MFC-7220 All-In-One Laser Printer
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
