Question about HP iPAQ H2215 Pocket PC
Unresolved Items when synching
I get an error message when resolving unresolved items during synchronizing process. The error message says "The following appointment cannot be written to Microsoft Outlook due to error 80004005. The item will be skipped". I have uninstalled and reinstalled Microsoft Outlook but that hasn't helped. Any idea's??
    Master:
  • 450 Answers
Try the following.... Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Now go back in to those Calendar settings, and set it back to the default which is 2 past weeks and All Future appointments. SYNC (this will now reload all appointments into your Ipaq)
Posted on Sep 08, 2005
What happen with Bitdefender antivirus, why it is not removing the virus?
The Virus Scanner scan log indicates there are still unresolved items. Bitdefender Antivirus The unresolved items in the scan log may be:
  • restricted access archives (xar, rar, etc.)Solution: Use the Reveal in Finder option to find the file and delete it manually. Make sure to empty the Trash.
  • restricted access mailboxes (Thunderbird, etc.)
    Solution: Use the application to remove the entry containing the infected file.
  • files owned by another user
    Solution: Use the Reveal in Finder option to find the file and contact the owner to find out if it is safe to remove that file. If it is safe to remove the file, delete it manually. Make sure to empty the Trash.
Jan 08, 2018 | BitDefender Computers & Internet
Find driver easy tv captuer saa7130hl
http://download.cnet.com/Philips-SAA713X-Hybrid-Capture-Device/3000-2110_4-156884.html
if this does not help try www.driverdetective.org free to scan your computer if it finds your driver you will have to pay to download
I scaned file it looks clean but you should save it to your desktop and scan it also. G.L.
Malwarebytes' Anti-Malware 1.50.1.1100
www.malwarebytes.org
Database
version: 6326
Windows 6.1.7601 Service Pack 1
Internet Explorer 9.0.8112.16421
4/24/2011 2:14:55 PM
mbam-log-2011-04-24 (14-14-55).txt
Scan type: Quick scan
Objects scanned: 1
Time elapsed: 1 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Nortons insite scan
Scan Statistics:
Scan Time: 1 seconds
Scan Targets: C:\Desktop\Temp download\Drv_ATSC110_Philips_V1.3.3.2.zip
Counts:
Total items scanned: 78
- Files & Directories: 78
- Registry Entries: 0
- Processes & Start-up Items: 0
- Network & Browser Items: 0
- Other: 0
- Trusted Files: 1
- Skipped Files: 0
Total security risks detected: 0
Total items resolved: 0
Total items that require attention: 0
Resolved Threats:
No risks have been resolved
Unresolved Threats:
No unresolved risks
Apr 24, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
When I turn the camera on it says "Turn the Power off and on again"! I do but keep getting the same message?
If turning the power on and off again does not resolve the error message, try doing a power reset.
If the issue is still unresolved, service may be required.
Jul 25, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Errors after building
ok DIALOGSET is referenced in your code but where is it declared , or defined, could be a class or structure etc.
May 30, 2009 | Compaq Digital Visual Fortran Standard...
Entourage Hot sync failure with Palm (error = #-1)
1. Right click Red/Blue synch icon in lower right corner
2. Select custom
3. See how many items are in two way synch
Sep 13, 2007 | Microsoft Entourage For Mac for Mac
How do I fix my Outlook Calendar synchronization problem?
Palm tech fixed my problem. It turned out some items in Outlook Calendar were corrupted, thus preventing a synch with LifeDrive. The fix is to export the Calendar items and import them. This process fixes corruption. After doing that I successfully synchronized Calendar with LifeDrive. More specifically. I moved Calendar items to a different folder, thus emptying the main Calendar folder. I exported the Calendar items in the new folder to a CSV (Windows) file. Then, I imported that CSV (Windows) file into the main Calendar folder. Finally,I did a synch and all worked perfectly.
Sep 13, 2005 | Palm LifeDrive Handheld
Why does pocket mirror trawl through all items when synchronising a calendar
The HotSync software on the Mac was never designed to cope with the scenario where you synch with a PC elsewhere. It assumes that you are performing a recovery synchronization when it sees that the handheld synched elsewhere. The assumption with the Palm OS was always that you synched one computer to one PDA. With more propsperous times, the software has not yet evolved at Palm Source (not part of Palm Inc any longer.) With regards to PocketMirror, there is a setting to allow you to synch to more than one PC. The setting is buried deep in the PocketMirror settings for each of the four conduits. The setting allows PocketMirror to see more than one PC as your route to an Exchange server.
Sep 11, 2005 | Palm Zire 71 Handheld
ActiveSync 'Unresolved Items'
At some point when I installed some windows updates, my Outlook started asking if I wanted to allow ActiveSync to access Outlook's data and for how long. Do you get a dialogue like this when you sync while Outlook is running? Could it be that when it's not running, you aren't given the dialogue and thus permission is not granted to ActiveSync to access the data?
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Unresolved items
This is more of an ActiveSync problem than an iPaq problem. Don't you just click "Resolve items" and ActiveSync either updates your handheld or the PC depending on which one you choose to get precedence?
Sep 11, 2005 | HP iPAQ H2215 Pocket PC
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
HP iPAQ H2215 Pocket PC Logo
225 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
