Question about Pentax Optio 450 Digital Camera
Power problem with 450
I have had the Pentax Optio 450 now for about four months. A great camera. I love the size, the 5X optical zoom, and most of the features. However, there appears to be an issue with the camera when I try to power the camera off. Sometimes the power will go off (LCD will go off) but the lens will not retract. This is intermittent. Sometimes it will and sometimes it will. When it doesn’t, it is a pain because I have to keep pushing the power button before it eventually comes back on. I then have to try it again to get the lens to retract. I sent it back to Pentax for repair and they sent it back (after about 5 weeks) and it still has the problem (I don’t know what they did but they didn’t fix the problem). Has anyone had this problem with the 450, 550 or 555 cameras?
    Master:
  • 542 Answers
This has happened once to me only. I noticed it started after the lens cover jammed one time. I gently flicked the lens cover shut and pulled the lens also gently when it was fully extended. Seemed to fix it. I had also uploaded the new foirmware at the same time so perhaps that fixed it ? Not sure which. The lens cover system is very flakey - it needs a cover itself as every time you put the camera in a case or in a tight pocket the lens cover gets slightly out of whack and jams. If it happens all the time then sounds like a defect.
Posted on Sep 08, 2005
    Master:
  • 542 Answers
It is not the auto-off. It happens about half the time when I push the on/off button - the power goes off on the lcd but the lens does not retract. It's dead. I can get it back on by pushing the on/off button several times and the unit will come back on. I then have to go through the process again. It's a real pain to get the lens to retract sometimes. I would like to think it is something simple, but I can't figure it out. I think it is defect.
    Master:
  • 542 Answers
The LCD goes dark after the camera has been inactive for a time, to save battery. When that happens, you can easily restore the LCD display by half-pressing the shutter. If you want to, you can turn this off by selecting menu-setup-SleepTimeout and turn it off. (I don't recommend it, though, as the LCD always on will drain your battery).
SOURCE:
What size memory card will my camera take
it will take 2 gigabyte card, ask your dealer if it will take more.
Sep 15, 2014 | Pentax Optio M20 7MP Digital Camera with...
Lcd screen of Pentax camera damaged, I am located at Indore, MP
Perhaps you just try to contact Pentax for this? But I think if you could buy a LCD screen, it will cost you more than a brand new camera, with better specs than your Optio M20.
So perhaps you start saving for a new camera?
May 04, 2014 | Pentax Optio M20 7MP Digital Camera with...
SDHC 16 GB memory card compatible with Pentax Optio 450
No, you cannot use SDHC cards with the 450. You can only use MMC and SD cards, 2GB and smaller.
Aug 01, 2012 | Pentax Optio 450 Digital Camera
I need a user manual for Pentax Optio e90 camera
You can download one at the support section of the Pentax website.
Oct 16, 2010 | Pentax Optio E90 10 MP Digital Camera with...
Want to buy pentax m40 camera
I would suggest to buy Nikon Coolpix S80 14.1 MP Digital Camera with 3.5-Inch OLED Touchscreen and 5x Wide-Angle Zoom Nikkor ED Lens.I have used this camera and it performs really well. http://hubpages.com/hub/Nikon-Coolpix-S80-141-MP-Digital-Camera
Jun 29, 2010 | Pentax Optio M40 8MP Digital Camera with...
What kind of an USB cable does the Optio 450 use?
You should get the original Pentax cable- the Pentax I-USB7 USB Cable for the Optio WPi, WP & S55 Digital Cameras. It's compatible with the 450 as well.
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Optio s5i Lens Stuck Problem
You can try removing the battery and leaving out overnight then putting it back and charging it up then try the power. This has worked for some people but not all.
Sep 08, 2005 | Pentax Optio S5i Digital Camera
Pentax Optio 450 Digital Camera Logo
79 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
