Question about Sewing Machines
Threading i am having problems threading my over locker it is the bottom that i cannot get right do you have any detailed drawings that i can follow thank you M Colley
  • Anonymous Dec 18, 2008
    I have the same problem, don't know how to thread it.
I have a new home LE sewing machine 108 . And I do not now how to thread it or to use bobbin , I want to sew so bad, and I have used sewing machines before . I have no manual any free manuals running around
Posted on Nov 03, 2008
I have a berndette over locker. Iam trying to thread the red loop that comes to the centre of machine before threading the needle. The lever seems to be stuck
Not sure I understand your question. Be sure to ALWAYS RAISE the presser foot when threading the machine and give each thread an extra tug when going through the tension mechanism. This allows the thread to seat in the tension disks.
Jan 05, 2018 | Sewing Machines
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
How to thread an empisal over locker ,DE-LUXE400
The manual should be helpful:
Empisal companion deluxe 400 user manual
It is always best to start out with brand new needles.
Before beginning to thread, be sure to ALWAYS RAISE the presser foot throughout the threading process. This releases the tension disks so the thread will seat properly.
Follow the thread order when threading or your machine will most likely never work properly. Usually, it would be the upper looper first, the lower looper next, and then the needles. However, your manual should clarify that. Also, when threading each, be sure to give each thread an extra little tug when it goes through the tension disk to make sure it seats correctly.
Empisal Overlocker Companion Deluxe 400 Manual downloadthefilenow com
Oct 15, 2016 | Sewing Machines
Baby locker has no stitch at all ive thread it just as shown on diagram , im so frustrated with it
Remove all the thread.
RAISE the presser foot. Then rethread from the beginning making sure you are following "each" thread's steps and that you are threading each thread in the "order" specified in the manual. (If any steps are missed or the threads are not done in correct order, the machine most likely will never work! Sergers are finicky machines!)
For most sergers, the lower looper thread's "final" step is to lay "over" the top of the upper looper before begin pulled under the presser foot.
Also, if a thread breaks or comes unthreaded, the best policy is to unthread and start over. Simply rethreading the one thread will "Not" work!
If you still can't get it to work, you might take it to a Babylock dealer and have them look at your threading. Could be something is wrong with the machine other than the threading.
Jan 31, 2016 | Sewing Machines
Threading the 634d took me over 8 hours to get the thread to go though the right needle. Is there an easier way?
Most new serger users have trouble threading the loopers. Something that helps me thread needles (sewing machine, serger, or hand needles) is to lick your index finger. Then swipe it across the back of the needle eye. The moisture helps draw the thread through the eye.
It helps to have the needle at the top of its cycle when threading, Removing the presser foot while threading the needle will sometimes help reduce the interference.. Be sure that your thread is not too big for the needle.
These videos may help:
Janome Threading the overlocker
Janome Domestic Overlocking Machine Tutorial
Don't feel bad. It took me 8 hours to thread my first serger, but my problem was getting the loopers threaded. Practice does make it easier...
Nov 06, 2015 | Sewing Machines
Can't figure out how to thread a Singer AK30037
There are generally markings on the machine; if you have followed those, you need to know that before stitching, you must draw the bobbin thread up to the top, and then hold both top and bottom threads loosely when you start up.
Dec 29, 2013 | Singer Sewing Machines
Help! I'm having problems with my Necchi Lydia 3. Firstly when threading up, the threaded needle refuses to draw up the bobbin thread. I've followed the instructions and the needle comes in and out but...
try a different bobbin
make sure the bobbin in turned the right way in the bobbin case
also the machine may have a timing problem, and having it checked to would be a good idea.
Sep 07, 2013 | Necchi 4575 Mechanical Sewing Machine
Drawing up the lower thread
Check the needle to be sure it is installed with the flat side to the back of the sewing machine.
Mar 03, 2010 | Brother LS-2125 Mechanical Sewing Machine
Threading a pfaff creative 7570
Always thread the machine with the presser foot up. This keeps the tension disks open while you are threading. Open the lid on top. Put thread on spool holder. Go directly to your left and down the path on the farthest left. Go all the way to the bottom and bring the thread up on the path closer to the spool. Hook the thread through the metal piece that moves up and down while sewing. It should be in the highest position when threading. Run the thread down and clip into the small metal holder above the needle. Pull down needle threader, draw thread across front of it from left to right and pull through needle.
Jan 30, 2008 | PfaFF Creative 7570
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
