I need a control knob for a Parkinson Cowan Windsor radiant gas fire urgently please
  • suealexander Sep 01, 2008
    When you only have one knob its a bit difficult and if it was that easy to take to a supplier would have done so first but no-one does them in my area and my tenant does not consider being told to use a pair of pliers to get the fire to work by her landlady suitable advise re health and aafety etc.! But hanks for trying anyway.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
If you have 2- knobs , just pull the one off the other to control both switches,or take the knob down to a repair , or supply house and get a matching pair, but for now, plyers! thank-you-very-much!
Posted on Aug 28, 2008
Wer is gas control knob
The black knob, in the video is the gas control knob. The red button is the pilot light button.
Oct 10, 2012 | Heating & Cooling
My heil furnance comes on but no hot air or air at all
see this causes and fix it. God bless you
o light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps: Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Oct 08, 2012 | Honeywell Icp Heil Tempstar Furnace Spark...
I have a Valor Eminence Gas Fire which does not ignite when i try to put it on. Pilot light seems to be going but no gas. Can anyone help? I habe dusted the interior as per instructions but to no succes....
Be sure that after lighting the Pilot, that you turn the gas control knob to ON. Just lighting the pilot will not turn the burners ON. Once the control knob is turned to ON, you can turn the burners ON.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
We have Rinnai in wall heater. when it is turned on it runs for several minutes before the gas cuts out
Currently, there are 3 models of Rinnai in built radiant heaters. Could you please provide the model number of your heater?
Thanks for choosing FixYa. Cheers
Aug 26, 2011 | Heating & Cooling
I need the manual for a 16 ins radiant gas inset fef fire with trim switch. No vent
To help you, I will need to know who the manufacturer is and the model number of the heater.
Please advise and thanks for choosing FixYa.
Aug 16, 2011 | Heating & Cooling
Gas fire place flame to low, do you have a schematic to increase the flame ?
Generally, whether it's a Vent-free or Vented fireplace, lower than normal flame height is caused by 3 things: Low Gas pressure; The air shutter control valve is clogged or needs adjusting; The burners need cleaning.
I haven't seen a unit in the past 10 years, that has a flame height adjustment, other the flame height control knob, that's part of the control assembly. Have you checked that, to see what height it's turned to low?
Perhaps, if I knew who the manufacturer was and the model number, I could be of more help to you.
Mar 15, 2011 | Honeywell Heating & Cooling
Remote controlled gas log fire will not ignite,relaced batteries,cleaned logs etc,worked a couple of times then refused to ignite again ,can hear ignition ticking but cannot hear any gas coming through ,...
If you're using propane gas, the banging noise you hear is air in the gas line, which means either your tank is empty or the the tank regulator is frozen (if it's ,below freezing in your area). If the tank regulator is frozen, soak a bath towel in hot water and quickly place it around the regulator. It should thaw fairly quickly and the gas will start flowing again. However, you may need to purge the air out of the gas line to gas log burner. Rather than using the electronic ignitor, do it manually, until you smell gas, left off the control knob and wait 5 minutes and then try lighting the pilot electronically.
If you're using Natural Gas, it may still be a pressure problem to the burner. You'll need to have that professionally checked.
Hope this helped to solve your problem.
Feb 27, 2011 | Heating & Cooling
I have a gas water heater, 6 years old. The pilot will lite and then the burner lites up, after several seconds the burner goes out. It won't stay lite. The other gas appliances are working. What's...
The Thermocouple, which is part of the ignition system may be loose, where it screws into the gas control valve. Or it needs replacing.
But, first turn the gas off to the water heater, allow the burner compartment to cool off and with a flash light do a visual inspection of the burner chamber. If you see rust or scale in the chamber or on the burner, it will need to be cleaned. You can use a wire brush to clean the burner, making sure you do it carefully and not too aggressively. Use a shop vac with a hose and crevice tool to remove the debris that was created when you cleaned the burner. Be sure to vacuum the burner ports well.
Look for the Thermocouple ... it will be in front of the pilot flame and look like a 2 to 3" long piece of copper. It will have a copper tube running from the bottom of it to the gas control valve. Does the Thermocouple look pitted and worn? Dos it have a hazy film on the tip? If so, use some very fine grit sand paper to polish the Thermocouple. You don't want to sand it, as much polish it. After you have completed that, use a cotton ball dipped in alcohol to wipe off the Thermocouple.
You remember the copper tubing I mentioned that runs from the Thermocouple to the Gas Control Valve? Trace that tuning to the control valve and see if you can loosen the connecting nut to the control valve with your fingers. If you can, it's loose and needs to be retightened. Finger tighten it and with an appropriately sized open end wrench tighten only 1/4 turn more. Turn the gas back on and light the pilot, following the lighting instructions on the water heater. Allow the control knob to remain in the pilot position for at least 1 minute before turning the control knob to ON.
The water in the tank has probably cooled enough that the burner should fire up. If it doesn't turn on the hot water side of faucet, to drain the tank some, so that the burner will fire.
Once it fires, take a stick match, light it then blow it out. Quickly place it next to the opening at the top of the tank where the Exhaust Vent Pipe is connected to the tank. If the vent is drawing properly, it should **** the smoke quickly up the vent pipe. If it doesn't, you'll need to check the vent pipe for obstructions or disconnections at the couplings along the pipe.
If the burner does not continue to operate properly after you have completed all of this. Replace the Thermocouple. Remove the one you now have and take it with you to a hardware or home improvement store, so that you can match it up to the ones that are available.
Hope all this solves your problem. Please let me know.
Feb 12, 2011 | Heating & Cooling
Just installed an A O Smith 50gal NG water heater.and can not get it to lit. I have checked the presence of gas at the control valve inlet. I have mechanically held the pilot knob on the gas valve...
Did you have the main gas valve shut off to the house? I know this sounds like a really dumb question, but if the gas line is installed and sealed properly where it goes into the control valve inlet, how did you go about checking for the presence of gas there? If there is in fact, gas going into the valve and no gas coming out at the pilot when you are holding the pilot knob, then you have to have a defective control or a pilot gas tube that is smashed completely shut. It is also possible that dirt and/or debris got into the control unit during the installation process and has things clogged up.
Jan 16, 2011 | Heating & Cooling
I have a parkinson cowan palma de-luxe universal 500 gas fire.I no longer have the details of the btu output and I need this information as my house is having cavity wall insulation. The surveyer told me...
Hello.They are worried about makeup/combustion air and rightly so.Your heater is probbally more then 7000btu(small) and a vent is a great idea.Maybe one that can be adjusted closed when not in use.Bahtroom fans,clothes drier,range hood & attic fans(if apply) all use makeup air also.
Sep 29, 2010 | Heating & Cooling
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
