Erased list in reg.key netsvcs - Computers & Internet
  • pksam Aug 28, 2008
    Sorry ,and thanks for answer it sure looks like the list i erased,i only have the netsvcs key on the left pane and 2x clicking on that displays 2 entrys in right pane:
    1...default..............................rz........................(no value)
    2...CoInitializeSecurityParam rz........................0x000000001
    so where does go and how is it entered ?thanks a ton best $10 I've ever spent. Warm regards Peter
    Guru:
  • 1,894 Answers
You will have to reinstall the operating system
else try to restore the OS
Posted on Aug 28, 2008
  • 1 more comment
  • dewan nafees ahmed Aug 28, 2008
    Go to Start -> Run, type in regedit and press Enter. Navigate to:
    HKEY_Local_Machine\Software\Microsoft\WindowsNT\CurrentVersion\SvcHost
    In the right pane, double-click to open the netsvcs key.
    this must be present inside the value
    6to4
    AppMgmt
    AudioSrv
    Browser
    CryptSvc
    DMServer
    DHCP
    ERSvc
    EventSystem
    FastUserSwitchingCompatibility
    HidServ
    Ias
    Iprip
    Irmon
    LanmanServer
    LanmanWorkstation
    Messenger
    Netman
    Nla
    Ntmssvc
    NWCWorkstation
    Nwsapagent
    Rasauto
    Rasman
    Remoteaccess
    Schedule
    Seclogon
    SENS
    Sharedaccess
    SRService
    Tapisrv
    Themes
    TrkWks
    W32Time
    WZCSVC
    Wmi
    WmdmPmSp
    winmgmt
    wscsvc
    xmlprov
    BITS
    wuauserv
    ShellHWDetection
    helpsvc
    WmdmPmSN
    thank you
    please dont forget to accept the solution if you are OK with it.
    thank you
    reinstalling service pack 2 of XP will also cure your problem.
    thank you
I want to delete the contact in my LG GS290 mobile
Have a nice day.
Here are the ways to delete the contact/contacts in your mobile phone:
From the main menu screen, press Contacts [Right Soft key].
Press Options [Right Soft key].
Select a contact from the contacts list.
Press the Right Soft key for options.
Scroll to Manage Contacts, press OK
Select Erase, press OK.
Press Right Soft key to select all or select desired contacts to erase by pressing OK to mark each contact.
Press Left Soft Key for Done.
Display shows Erase Contacts?
Select Yes, press OK.
Hope it can answer your question,
Thank you for using fixya.
Adieh
Sep 12, 2011 | Cell Phones
I CANT DELETE CONTACTS lg gs290
If this does not work, "Power the phone off for 30 minutes and then power it back on and try it again."
Regards
Jul 18, 2011 | Cell Phones
Erase missed calls on panasonic dect 6.0
I found a way. Press the menu button on the phone. Then it should say "View Caller ID". Press the menu button again. You should see one of the missed calls you had listed. Now press the mute key. It should show a screen that says, "Erase? -Yes -No". On this screen, press the mute key a second time. It should now show "Erase" in larger font. Press the down arrow on the D-pad. It should now say "Erase all". Press the menu key, and if it worked, "No items selected" will show up on the phone.
Hope this works for you.
Feb 18, 2011 | Panasonic KX-TG1033S Cordless Phone
Memory is full. How do I erase the memory
The "Out of Memory." message means the memory capacity of the unit has been exceeded. Please follow the steps below to resolve the issue.
>Please press Menu, press the Up or Down Arrow key to select Fax and press OK.
>Please press the Up or Down Arrow key to select Setup Receive and press OK.
>Press the Up or Down Arrow key to select Memory Receiveand press OK.
>And, press the Up or Down Arrow key to select Off and press OK. Please read the section carefully.
If you have faxes stored in the memory, you will receive one of the following message:
>Erase All Fax (Doc) ?
Print All Fax?
>If you press 1(Yes), faxes in the memory will be erased or printed before the setting changes. If a backup copy has already been printed it will not be printed again.
>If you press 2(No), faxes in the memory will not be erased or printed and the setting will be unchanged.
You can also refer the steps mentioned on the page below.
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000100/000095/faq000195_031.html?reg=us&c=us_ot&lang=en&prod=mfc490cw_all
Jul 02, 2010 | Office Equipment & Supplies
Delete from add delete at control panel
The only way to modify the add/remove programs list is to edit the registry. If you are uncomfortable doing this, get someone to help who is, or just leave the registry alone.
It's best to back up the registry in case you make a mistake.
To back up your registry, see this article.
On to the fun part. Follow these instructions exactly. Note: this applies to Windows XP only. If you have Windows Vista, please modify the question.
  1. Click Start, and then click Run.
  2. In the Open box, type regedt32, and then click OK.
  3. In Registry Editor, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
  4. In the left pane, click the Uninstall registry key, and then click Export on the File menu.
  5. In the Export Registry File dialog box that appears, click Desktop in the Save in list, type uninstall in the File name box, and then click Save.
  6. Each key listed under Uninstall in the left pane of Registry Editor represents a program that is displayed in the Currently installed programs list of the Add or Remove Programs tool. To determine which program that each key represents, click the key, and then view the following values in the details pane on the right: DisplayName: The value data for the DisplayName key is the name that is listed in Add or Remove Programs.
    -and-
    UninstallString: The value data for the UninstallString key is the program that is used to uninstall the program.
  7. After you identify the registry key that represents the program that you removed but which is still displayed in the Currently installed programs list of Add or Remove Programs, right-click the key in the left pane of the Registry Editor window, and then click Delete.
    Click Yes in response to the "Are you sure you want to delete this key and all of its subkeys?" message.
  8. On the File menu, click Exit to quit Registry Editor.
  9. Click Start, click Control Panel, and then click Add or Remove Programs.
    In the Currently installed programs list, verify that the program whose registry key you deleted is no longer listed.
  10. Do one of the following:
    • If the program list is not correct in Add or Remove Programs, double-click the Uninstall.reg file that you saved to your desktop in step 5 to restore the original list of programs in the registry.
      -or-
    • If the program list is correct in Add or Remove Programs, right-click the Uninstall.reg file on your desktop, and then click Delete.
Mar 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
How do I erase received calls?
On mine, I use the directional key to where the display reads "Caller list - X Received calls" - Press the "clear" button from there to completely clear the caller ID.
Mar 03, 2009 | Panasonic KX-TG1033S Cordless Phone
System restore on server 2003
Before we begin, you'll need an XP CD. Doesn't matter if it's home or pro. It shouldn't matter if it has a service pack on it, since all the files will be the same source. In testing i used a slipstreamed cd that already had sp1 on it.
In XP, system restore is installed in syssetup.inf under the inf.always section. If you have XP installed, you can open up %windir%\inf\syssetup.inf and search for [Infs.Always], you'll see the section xp looks at for installing system components. You'll notice it has sr.inf, this is the inf for system restore. For server 2003, if you look at syssetup.inf you won't find sr.inf. This doesn't mean system restore won't work in server 2003, it just means they didn't install it.
So first what we're going to need to do is right click on sr.inf and select 'install', to install it on server 2003. If you have xp installed on another computer/partition you can just right click on it. If you don't, then extract \i386\sr.in_ from the XP cd to your desktop, then right click on it and select 'install'. It'll prompt you where the files are, point it to the XP CD. Once done, it'll prompt to restart, say yes.
That was easy, the next part is the tricky part. After restarting you'll get an error saying the service couldn't start. Specifically the error is error 1068. I searched google and found this link -
CODE
http://www.aerdyne.com/Kbase/article_000005.htm.
The error basically means it cannot run under the service it's on. In system restore's case, it runs under the network service. I know this because in services.msc, for path to executable, it says this: C:\WINDOWS\system32\svchost.exe -k netsvcs. This got me thinking so i opened up sr.inf, and found this line:
[SRSvc_delreg]
HKLM,"Software\Microsoft\Windows NT\CurrentVersion\SvcHost","SRGroup"
I opened up regedit, and this registry key didn't exist. So it seems the sr.inf doesn't register system restore to run under the network services group. Using the above registry key as an example, i opened regedit and went to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost
On the right hand side i saw netsvcs. I double clicked on it, but saw SRService no where (SRService is the name for system restore). On a hunch, at the bottom i added SRService, rebooted, and this time got no error on startup. I opened up rstrui.exe, and system restore opened fine. I also had a System restore tab in system properties now too. I was able to make a restore point fine, then restore the computer to it without any problems. So in the above key, you want to double click on netsvcs, and at the bottom of the list, you want to type in SRService (probably case sensitive).
If you're not good with the registry you can save the following as a whatever.reg file and import it, but because it's binary i can't say if it'll work. I recommend manually adding SRService to the netsvcs key.
---copy below to whatever.reg then double click on it -----
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost]
"netsvcs"=hex(7):41,00,70,00,70,00,4d,00,67,00,6d,00,74,00,00,00,41,00,75,00,\
64,00,69,00,6f,00,53,00,72,00,76,00,00,00,42,00,72,00,6f,00,77,00,73,00,65,\
00,72,00,00,00,43,00,72,00,79,00,70,00,74,00,53,00,76,00,63,00,00,00,44,00,\
4d,00,53,00,65,00,72,00,76,00,65,00,72,00,00,00,45,00,76,00,65,00,6e,00,74,\
00,53,00,79,00,73,00,74,00,65,00,6d,00,00,00,48,00,69,00,64,00,53,00,65,00,\
72,00,76,00,00,00,49,00,61,00,73,00,00,00,49,00,70,00,72,00,69,00,70,00,00,\
00,49,00,72,00,6d,00,6f,00,6e,00,00,00,4c,00,61,00,6e,00,6d,00,61,00,6e,00,\
53,00,65,00,72,00,76,00,65,00,72,00,00,00,4c,00,61,00,6e,00,6d,00,61,00,6e,\
00,57,00,6f,00,72,00,6b,00,73,00,74,00,61,00,74,00,69,00,6f,00,6e,00,00,00,\
4d,00,65,00,73,00,73,00,65,00,6e,00,67,00,65,00,72,00,00,00,4e,00,65,00,74,\
00,6d,00,61,00,6e,00,00,00,4e,00,6c,00,61,00,00,00,4e,00,74,00,6d,00,73,00,\
73,00,76,00,63,00,00,00,4e,00,57,00,43,00,57,00,6f,00,72,00,6b,00,73,00,74,\
00,61,00,74,00,69,00,6f,00,6e,00,00,00,4e,00,77,00,73,00,61,00,70,00,61,00,\
67,00,65,00,6e,00,74,00,00,00,52,00,61,00,73,00,61,00,75,00,74,00,6f,00,00,\
00,52,00,61,00,73,00,6d,00,61,00,6e,00,00,00,52,00,65,00,6d,00,6f,00,74,00,\
65,00,61,00,63,00,63,00,65,00,73,00,73,00,00,00,53,00,61,00,63,00,73,00,76,\
00,72,00,00,00,53,00,63,00,68,00,65,00,64,00,75,00,6c,00,65,00,00,00,53,00,\
65,00,63,00,6c,00,6f,00,67,00,6f,00,6e,00,00,00,53,00,45,00,4e,00,53,00,00,\
00,53,00,68,00,61,00,72,00,65,00,64,00,61,00,63,00,63,00,65,00,73,00,73,00,\
00,00,54,00,68,00,65,00,6d,00,65,00,73,00,00,00,54,00,72,00,6b,00,57,00,6b,\
00,73,00,00,00,54,00,72,00,6b,00,53,00,76,00,72,00,00,00,57,00,33,00,32,00,\
54,00,69,00,6d,00,65,00,00,00,57,00,5a,00,43,00,53,00,56,00,43,00,00,00,57,\
00,6d,00,69,00,00,00,57,00,6d,00,64,00,6d,00,50,00,6d,00,53,00,70,00,00,00,\
77,00,69,00,6e,00,6d,00,67,00,6d,00,74,00,00,00,77,00,75,00,61,00,75,00,73,\
00,65,00,72,00,76,00,00,00,42,00,49,00,54,00,53,00,00,00,53,00,68,00,65,00,\
6c,00,6c,00,48,00,57,00,44,00,65,00,74,00,65,00,63,00,74,00,69,00,6f,00,6e,\
00,00,00,68,00,65,00,6c,00,70,00,73,00,76,00,63,00,00,00,75,00,70,00,6c,00,\
6f,00,61,00,64,00,6d,00,67,00,72,00,00,00,57,00,6d,00,64,00,6d,00,50,00,6d,\
00,53,00,4e,00,00,00,53,00,52,00,53,00,65,00,72,00,76,00,69,00,63,00,65,00,\
00,00,00,00
--- copy above --------------------------------------------------------
That's it! Remember to restart both times.
Oct 20, 2008 | Computers & Internet
Help and support center
Girish,
Open the taskmanager and click the processes tab and look for these processes and end them if they are running.
  • helpsvc.exe
  • helphost.exe
  • helpctr.exe
  • Close your taskmanager and go to start, run and type CMD you will now have the command box open you will need to type each of these lines and hit enter after.
    net stop helpsvc
    cd /d %windir%\pchealth\helpctr
    rd packagestore /s /q
    rd installedskus /s /q
    cd binaries
    start /w helpsvc /svchost netsvcs /regserver /install
    start /w helpsvc /register
    The line "start /w helpsvc /svchost netsvcs /regserver /install
    " is what reinstalls the help and support service and may take a little while to run.
    Credit for this fix goes to http://windowsxp.mvps.org/rebuildhelp.htm
    Jul 11, 2008 | Computers & Internet
    Need to erase all programs
    There are two ways of doing this.
    Hit the 2nd key
    Then the "+" key
    Then the 7 key
    Then the 1 Key
    then the 2 key
    This will delete your whole ram. and clear everything. your calculator will be fine but all your list and data that you might have will be gone
    Or You can
    hit the second Key
    then the plus key
    then the 2 key
    Then hit enter
    and you can delete the programs you want by pressing the del key
    This will just delete your programs and nothing else
    Dec 13, 2007 | Texas Instruments TI-84 Plus Calculator
    Computers & Internet Logo
    David Payne
    David Payne
