Question about Samsung CLX-2160N All-In-One Printer
PaperJam I use the printer every day, it was still working but Now it gave a paperjam, as i have removed the paper (in one piece), the printer still say that there is a paperjam. What can I do to solve the problem
  • 1 more comment
  • Anonymous Oct 24, 2008
    I have the same problem of paper jam. I had to have one machine replaced and now the new machine is paper jaming. It is in such a way I can not reach the paper to free it. The previous machine took in paper and hid it somewhere so it could not be found when the technition looked at it. The new one has just done the same. The machine gets so hot that I have burned my fingers trying to follow the instruction to free paper jam.
  • Anonymous Jan 31, 2009
    njepcservice - could you please describe what piece of plastic you mean in more detail ? Thanks !
  • Maria Batista Feb 17, 2009
    It says there is a paper jam there isn't. it doesn't take the paper but tries and damages it while still in the tray
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Posted on Nov 17, 2008
Paperjam in hp 1000 printer
two reason in paperjam 1200 series printer
one some senser not working so remove back sight cover and clean dust help with air blower.
and paper pick roller is not working
first you remove paper pick roller
and change direction of paper pick roller
means change direction means just opposite site use.
i think solve your problem.
Apr 10, 2010 | HP LaserJet 1200 Printer
Lexmark T642 Printer giving me a paperjam error#241.10. There is no paperjam
Normally this is caused by either a small piece of paper stuck in a sensor or a bad sensor. Lots of times printers use optical detectors and it may just have paper dust causing a sensor to think there is a stuck piece of paper. Give the printer a through cleaning and let me know what happens.
Mar 20, 2010 | Lexmark T640 Laser Printer
Paperjam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Canon MX300 Office All-In-One Printer
MY PRINTER SAYS PAPERJAM AND ICAN'T REMOVE IT. iT IS A LEXMARK5600
Hello there
Mar 05, 2010 | Office Equipment & Supplies
Showing paperjam
Hello there
Feb 26, 2010 | Lexmark X5470 All-In-One InkJet Printer
310, 311 318 paperjam can not find it
is the paper in the fuser, try turning the fuser, sometime there are some small pieces of paper stuck in between the fuser and pressure roller
Feb 18, 2010 | OKI C3200n Led Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
CANON PIXMA MP180/MP160 PRINTER ERROR CODE E3 FOR PAPER JAM THERE IS NO PAPER JAM Can you give the solution about this problem? please share yout Idia...The problem of MP180 is paperjam i am repetedly...
Hello There please try it may clean it up for you There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Feb 28, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
Samsung CLX-2160N All-In-One Printer Logo
307 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
