Question about HP iPAQ RX3115 Pocket PC
Internet connection RX3115
I can't connect to the internet when I am using the USB cable to my computer. What do I need to do to enable IE?
    Master:
  • 450 Answers
You need to enable passthrough.
Posted on Sep 08, 2005
EFI/Mircrosoft/Boot/BCD
It's not clear what exactly you mean. Generally, you don't connect two computers together using a USB cord. You can use a "cross-over ethernet cable" to connect the network jack of one computer to another computer. This allows transferring files and/or sharing an internet connection. If you have a wireless router you can enable Windows "File and Printer Sharing" on each computer and transfer files that way. Please provide more details of what you're trying to accomplish by connecting the computers together with a USB cable, and we may be able to give you a more specific answer.
Jul 30, 2014 | E-Machines eMachines Desktop PC
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
How can i connect PC with Xp installed to laptop lenova with windows 7 installed.
if you want to connect both computers in a network the only thing you need is Ethernet cable. if you want both computers to share internet connection you need a router. connect your modem in the router and connect both computers in the router. there are also wifi enable routers wherein you can connect both of your computers wirelessly if they are wifi enable devices.
Apr 20, 2011 | Computers & Internet
Sir what purpose usb port and what purpose ethernet port are in zxdsl 831aii modem.
You can connect it to the computer either thorough USB or Ethernet depending on which connection you would like to use Ethernet is a better choice.
Mar 02, 2011 | Computers & Internet
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How to connect htc smart to computer for surfing internet
Using USB...
On the phone, goto Start, Programs, choose internet sharing. On the computer, make sure that activesync doesn't think it is connected, and plug in a mini-usb cable into the phone. After a moment, Windows should detect the new "network connection" and take over from there.
Using Bluetooth,
Open the bluetooth manager. Setup a partnership with the phone (pairing). Once done, goto properties for the partnership, and check "enable network capability' or similar. On the phone, goto Internet Connection Sharing, and switch from USB to Bluetooth. Note, you phone needs to be paired with the computer already.
Sep 22, 2010 | HTC Cell Phones
Wireless router wont connect to the internet
this would be mine that no computer is connecting to the Internet right now?
here's what we need to do. We need to identify first what Internet connection type you have in there.
have checked connection on the network as well, first and foremost - modem-router-computer is the connection you have.
For cable connection, you need to do a mac cloning on the computer
For DSL connection you need to have a PPPoE connection type on the router
For cable connection:
> access the router setup screen -
> on your IE - address bar 192.168.1.1
> no username and password is admin
> on the setup tab there is a mac clone service
> enable it and hit the clone button
> save the settings after
For DSL connection:
> under setup tab - look for internet connection type
> set it to PPPoE connection
> try to connect and save the settings there.
Jul 12, 2009 | Linksys Wireless-G Broadband Router
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
HP iPAQ RX3115 Pocket PC Logo
50 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
