Question about Haier Washing Machines
The machine shows error 3 once the cycle has been completed
  • 639 Answers
Dear friend,
ngfam at you service!
Codes can only be diagnosed buy service !
No choice but to let them do it!
If the washer is 10 years or older its not worth investing money to fix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
Error code F13 showing on whirlpool ghw9300pw2, please help
Controller fails to detect door lock triac correctly This error code is displayed if the main control unit fails to detect the door lock triac correctly. Also, if the controller cannot unlock the door after 240 seconds after the cycle is completed then this error will be shown.
If displayed switch the washing machine off completely, recommend disconnecting it from the mains supply for a few seconds. Switch it back on and the controller will attempt to unlock the door once more but, if it fails to do so in the same 240 seconds the error code will be displayed once more.
  • Check all wiring and connectors between the main controller and the door lock
  • Check main control unit, probably requires to be replaced
Mar 09, 2015 | Whirlpool Washing Machines
My cabrio washing machine want start
start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Post the results back to me.
Nov 30, 2012 | Washing Machines
My cannon printer shows Error Code 3. What does it mean please? Thank you.
Hello Gm,
Please check printer is turned on by pressing the "On/Off" button, you will notice the display prompt you for E3 (error 3). Press and hold the "On/Off" button for one second. The display will go blank and begin resetting the malfunction. Wait 10 to 15 seconds and restore power to the unit by pressing the "On/Off" button once more. Allow the unit to complete its cycling process and the error code should be gone. If the code persists, your printer will need professional maintenance.
May 19, 2011 | Office Equipment & Supplies
Error 3 showing
Follow the below mentioned steps to resolve the issue : 1. Ensure the Pixma is turned on by pressing the "On/Off" button, you will notice the display prompt you for E3 (error 3).
2. Press and hold the "On/Off" button for one second. The display will now go blank and begin resetting the malfunction.
3. Wait 10 to 15 seconds and restore power to the unit by pressing the "On/Off" button once more.
4. Allow the unit to complete its cycling process and the error code should be gone. If the code persists, your printer will need professional maintenance.
Apr 22, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Feb 17, 2009 | Haier HWD1000
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Frontload washer will not complete a load..shows E3 on display
e3 is a motor sensor not reading the motor properly un plug the unit for 5min and try it that will clear it but you may need a new sensor check the connectors at the motor sensor
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
HE2 front loader error code
According to the HE2 Tech Service manual, it means "Suds Lock (Overdose of detergent detected during the wash cycle).
Aug 29, 2008 | Kenmore 43142 Front Load Washer
Bendix w1063B Allegro Front Loading Washing Machine
Make sure that the spin cycle is complete.
it has a timer/switch set @ about 3 min. You will observe a yellow pilot light.
It will show with a green pilot light when to press the open button.
Good luck,
marty
Apr 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Cleaning coffee maker
Decalcify with 1/3 cup white vinegar and 2/3 cups water. Turn on your machine and let it brew the mixture through the entire cycle. When cycle is complete empty the pot and fill the reserve with fresh cold water and cycle once more. This should clean your unit and if it doesn't do as good a job as you want then complete the entire process once more.
Info per my user manual on my different brand coffeemaker.
Coffeediva22
Jan 13, 2008 | Braun Aromaster KF 400 Coffee Maker
Washing Machines Logo
150 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
