Question about HP Pavilion zd8000 Notebook
I have red line in my laptop model hp pavilion
What that line appear in my laptop screen ,red line
  • Anonymous Dec 06, 2008
    iam from egypt and baught that zd8000 from paris, it had he same problem and it was from the vga card on the moherboard, but here in egypt they replace this chipset with a compatible one but take high price about 150 $ , but iam sure that somewhere in europe they can fix it and replace that damaged or burnt chipset
    Best regards
  • 186 Answers
First, we need to check whether the issue is with the LCD or with the Graphic Card of the Notebook because of which the line appears.
Do the steps below to check this :
Try connecting a Desktop Monitor to the VGA Port of the Notebook and press FN + F4 once the Monitor is turned on.
You should get the Display of the LCD on the Desktop Monitor connected to the Notebook.
If you see the line also on Desktop Monitor connected, the issue is with the Graphic Card.
However, if the Line appears only on the LCD of the Notebook and not on the Desktop Monitor, the issue is with the LCD.
In both the situations, the Notebook needs to be repaired.
Either the LCD needs to be replaced if the issue is with it or the Motherboard needs to be replace if the issue is found to be with the Graphic Card since the Graphic Card will be soldered on to the Motherboard and it cannot be replaced alone.
In both the situations, I recomend you to go for a new Notebook rather than getting this one repaired as you will get all the latest hardware components for the price you get it repaired.
Hope this helps...
Posted on Sep 03, 2008
Pavilion dv4 display horizontal flashing lines across the lower screen in taskbar area
I'm Sorry to say but it could be that you need a new screen (easy repair around $195) unless you go to HP
Or it could be the built in video card (much harder to repair)
Do the lines appear from start up or slowly get worse as the comp gets hotter, if this is the case it is more likely the video card then I would contact HP to get a quote, But first,
Try plugging your laptop into an external monitor & see if the lines show up then
Nov 26, 2013 | HP Pavilion dv4000 Notebook
Pavilion Laptop Screen Problem
It sounds like your screen was man-handled. You will need to replace the screen. You can sometimes buy them used online or you can get a new one from HP. Sorry for the inconvenience.
-Paul
Jul 12, 2010 | HP Pavilion dv6000z Notebook
Problems with HP Pavilion zd8000 PC Notebook? vertical lines appear on screen
Your screen has a faulty connection you will have to replace the screen.
Feb 22, 2010 | HP Pavilion zd8000 Notebook
HP Pavilion dv2700t is facing display problems. On start up, horizontal lines appear on screen and screen gets blurred completely.
uninstall the graphics driver and install it if that does not work then format the laptop with partion if that does not work concern with a hardware professional
Dec 08, 2009 | HP Pavilion dv2700t Notebook
Vertical lines have appeared on my hp pavilion zd8000 can u tell me how to fix it please?
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mptherboard. If the problem appears on both screens, external and laptop, most probably the video card/motherboard is defective.
Have it checked/repaired by a professional.
Oct 08, 2009 | HP Pavilion zd8000 Notebook
Lines on screen
I was going to ask to define lines, but if you have lines (red, green or white) usually means the screen is dying.
Full lines across the screen (such as in the case of my wife's laptop) mean the screen is dead. In either case, replacing the LCD is in order.
Good luck
God Bless
-Carlos:
Jun 12, 2009 | HP Pavilion dv8000z Notebook
Thin Red Line on Left Side of HP Pavilion DV2000 Lap Top Screen
Majority of time it's the lcd that has a problem which creates the red line, otherwise it's the GPU (video processor).
Try hooking up your computer to an external monitor. If you see the line on the external chances are it's the lcd.
This method of testing isn't fool proof but either way the problem is hardware related.
Let me know if you have any other questions.
Mar 04, 2009 | HP Pavilion dv2000t Notebook
Vertical lines in my laptop screen
Hi, that sounds like the integerated video graphics is going bad and it's not actually the screen. the zd7000's were known for video graphics failure. there was a lawsuit filed against hp for the zd models about a year ago to get a free motherboard replacement because of the video issue but it's too late to send it in now for the free repair. the zd models don't have a replacable video card in them like most laptops which the only way to fix the problem ould be to purchase another motherboard, you could try ebay but they're not that cheap. Rick
Mar 02, 2009 | HP 336084-6C0 - HP Pavilion zd7000...
Lines on my screen
I had the same issue awhile back....the only thing you can do is send it in....its a hardware issue inside the pc. nothing can fix it without taking your pc apart.
Nov 11, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion zd8000 Notebook Logo
132 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
