Question about Intel D101GGC Motherboard
No boot but a 5-second beep
I have D101GGC Motherboard. When I switch on my computer, it beeps with beep sounds durated 5-seconds as long as it is on. What might be the problem?
  • 1 more comment
  • arnavsaxena Oct 10, 2008
    no boot..
    continuous 3 second beeps... till the thing is powered off..
    mobo light's on..
    no clue whatsoever as to what could be wrong...
    had just installed a new SATA hard disk... went well for around a week till when this problem started...
    what could possibly have gone wrong
  • C3L0RN Dec 18, 2008
    ERr... i am having an issue like this as well, and it's not memory (does the same thing with NO ram in it) changed the psu as well... going to try another board.
  • ramzan_ali Dec 19, 2008
    restarat
  • 37 Answers
Sounds like your memory is messed up, try some different memory in your PC.
Posted on Aug 29, 2008
No boot
The beeps are possibly post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in
Test all power and data leads that attach from motherboard to your hard drive IDE SATA
make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat 40 pin ide it will be the first to fail
check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it
restart your computer the found new hardware wizard should activate
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error
also check the keyboard for secure dust free connection ps2 and or usb
hope this helps
Jul 26, 2012 | Intel D101GGC Motherboard
I have a HP a6300f computer. It won't boot. Once I turn it on, it beeps for 17 seconds, is silent for 10 seconds, and follows by another beep for 17 seconds. I'm not sure what the problem is.
The duration and time of the beep codes is going to tell you what the problem is..
Here is the hp page that has the beep code information.
HP Beep Codes
The specific beep code info is towards the bottom.
Hope this helps
Aug 29, 2011 | Computers & Internet
I use D101GGC motherboard with pentium 4 with HT processor. My system does not boot and gives long beep for 5 seconds and silent for 3 seconds and again long beep for 5 seconds. When the computer...
This is a problem with the memory or motherboard. Troubleshoot the RAM first by cleanning the contacts or replacing with a good one followed by the display card and then the motherboard.
Sep 21, 2010 | Intel D101GGC Motherboard
G31TM-P21 normally boots with series of beeps. Now will not boot properly from CD start sequence (for reinstalling op system) and gives a short beep about every 5 seconds. No information found on MSI...
According to the sequence of beeps your getting from your computer, ther is a possibility that there is a problem with the memory module or RAM on your computer. Try reseating the memory then try to boot up again.
Cheers!!
Sep 02, 2010 | MSI G31TMP21 (890552671946) Motherboard
Wont boot up. Just beeps every 5 seconds and a
Is the beep a moderately high tone that lasts for about two seconds? If so, this is the firmware loading signal, which sounds only when the power button is held in on powerup. This would indicate that your power switch has a mechanical or electrical problem and is not releasing.
If this is not what you are hearing, please provide more detail.
Jun 18, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Motherboard
TAKE YOUR DDR CARDS OUT ,, AND SWITCH THEM,, ,,IF THAT DOESNT WORK TRY WITH ONE AT A TIME,, GOOD LUCK
Oct 05, 2008 | AOpen MX46-533V (91.89U10.061) Motherboard
6-second on and 5-second off beeps from motherboard
try different memory, this seems to be a common problem with those motherboards.
Aug 28, 2008 | Intel D101GGC Motherboard
Beeping with no boot up
Beep codes mean something has gone wrong with the computer. Beep codes most likely happen for: Memory, Processor, Motherboard.
Try reseating the memory in the computer.
Jul 11, 2008 | AOpen XC Cube EZ65 Barebone
Intel D101GGC Motherboard Logo
253 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
