Question about Dell OptiPlex 170L PC Desktop
No network icon
I just reformatted my HD, new win xp pro. the is no network/LAN installed?
You need to go to the Dell site and download the BROADCOM 57xxx Driver!!!!!!!!! Tom.
Posted on Aug 28, 2008
I have Albatron PX865PE Pro motherboard. After formatting HD and reinstalling new windows XP everything was ok until I reinstalled the software of WIN TV card which card was already on the pc. After the...
I have found that if using a previous used hd and just reformatting the drive wouldn't allways work with some software and some pci cards.
I found out that using a data eraser first on the hd,then installing windows fully,then add the add-ons(pci Boards) and software as directed works fine.
(data eraser) my software overwrites with 00 all of the drive including the system files.
Sep 08, 2010 | Albatron PX865PE Pro Motherboard
Advent 7084. Tried to change back to XP from Win7. Reformatted HD but install did not complete. Now machine will not run after Intel splash screen. I have tried pressing F10 repeatedly after switching on....
Did you use the Advent's built-in reformat and rebuild to get it back to XP Pro?
If you have a separate XP Pro CD or DVD, as opposed to that in a 'hidden' partition on the HD, your best best, so long as you have the installation key, is to start fresh with formatting the HD and, if it is large enough, splitting the HD into two partitions.
Then use one of them for the actual XP Pro partition. Build that first partition into XP Pro, and when it is working properly, only then do you format the second partition, and make it into the kind of space you need it to be.
You should have the ability to make it work now. So long as you have a legitimate installation key for XP Pro, you should be able to make this work properly.
-a.
Jul 05, 2010 | Computers & Internet
I reformatted my compaq presario laptop using winXP pro, v.2002. It wasn't the original OS installer that came with the laptop, it was one my friend lent me. The problem is, the network adpater icon...
while reformating the lan drivers and other related drivers are being wiped out. so load your lan driver software again. if you find it hard to get 1, then goto www.hp.com and refer your model, then get all drivers from the site. to be more sure if your drivers are not installed,go on device manger, and check the question mark(?) with yellow colour, all those are not installed..load it
Oct 21, 2009 | Microsoft Windows XP Professional With...
INTEX LAN Card 8139D RTL problem
you need to download the driver for your lan card. If the LAN card came with your computer, go to the computer manufacturer website to get the driver
Jul 04, 2009 | Computers & Internet
My acer aspire 3690 laptop w/ Win Vista was bugged with virus so I had to reformat it. Itinitially, the recovery disk, which I made for the unit when it was still new, don't seem to work. So I was forced...
Dear Friend,
                 Kindly download the file from the below mentioned URL
URL for XP:          http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Acer-Aspire-3690-LAN-Driver-4370.shtml
Regards,
Aysaamy
May 02, 2009 | Computers & Internet
I have a Fujitsu Lifebook P-2040 that I just reformatted. I'm going to install Windows 2K Professional (don't have the restore disks for XP Home). After I reformatted and restarted, nothing happens. There...
Is there any reason for your preference for Win 2K over Win XP Pro? XP Pro would be a better choice over Win 2K.
You may be able to selecting the CD as the alternate boot device by pressing F12 as the laptop is booting up.
I am not familar with BIOS key on your laptop but you can try these keys on a cold boot up (don't use a warm boot up - Ctrl+Alt+Del keys). Try:-
Del
F1
F2
F10
Ctrl+F1 or F2
Alt+F1 or F2
Esc+F1 or F2
Once you get into the BIOS you can change the boot order, set the CD as the first device. You should be able install Windows from the CD.
If these keys don't work go to the Fujitsu WEB site to download the manual, whilst you are there you will also need to download the drivers for your model laptop the Windows version of the devices that are installed on your laptop eg. audio, video, modem, LAN etc. These need to be installed after the Windows installation.
Dec 20, 2008 | Fujitsu LifeBook P2040 Notebook
NT4 sees XP Pro in network neighborhood, but access denied
If you arent too worried about security since it is at home, enable the guest account on the windows XP machine, also disable the firewall on the XP machine ( it is on by default )
let me know
Oct 29, 2008 | IBM NetVista PC Desktop
Xp format problem
Assuming that you have both XP's on the drive, when it boots up, have you selected and tested both? OR
Did you format the entire drive and wipe the old system off, replacing it with the new install?
The simplest why to fix is to boot up on the Pro CD and format the entire drive and install new system. It sounds like your old info may still be there, but you can't get to it. Try the different boot option and burn your desired data to keep to a cd, then do the simplest. Don't worry about the system drivers, you can recover them from the restore cd or download them from the Dell.
The Pro XP will be able to recover your system enough to get the drivers on line.
No big deal, just time consuming.
Good Luck
Feb 14, 2008 | Dell Dimension 2400 PC Desktop
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Dell OptiPlex 170L PC Desktop Logo
41 people viewed this question
Alun Cox
